Lawrence T-D
This has happened twice now. I get in the truck, start her up, turn on the audio and find that I can't select sources. Worse, once the audio is on, it won't turn off! Both times I stopped the engine, opened the door to cut all accessories off, restarted and it was still doing it. The fix, I discovered, is to walk away from the truck and get the fob out of range, wait a minute or so and then go back and start it and the problem has cleared. Very annoying!
So I tried to see if I could update my software/firmware over Wi-Fi and the truck would not connect to my home WiFi or my iPhone 8+ hotspot. I don't want to enable the AT&T WiFi feature as I don't need another bill!
I checked my firmware version and on Ford's website and it says I am current. Anyone else had these 2 issues?
