Wayne Decker
From what I read, I can drop the TT tongue down by reducing the number of links on the Sway Pro. .
But that would take weight off the front axle.
That's as low as she will go on that shank. Notice, however though, that both propane tanks are missing. Also, I had no gear inside. She levels out with weight. From what I read, I can drop the TT tongue down by reducing the number of links on the Sway Pro. But from a measurement standpoint, the trailer tongue is 2" exactly lower than the ball when standing on it's jack leveled out. That's inline with how Blue Ox says it should be.
The correct solution is to buy a new shank with more drop. Here’s the one I use: Equal-i-zer 92024214 Adjustable Shank https://www.amazon.com/dp/B00AZS95KI/ref=cm_sw_r_cp_apip_UANDmlDlDhLMRThat's as low as she will go on that shank. Notice, however though, that both propane tanks are missing. Also, I had no gear inside. She levels out with weight. From what I read, I can drop the TT tongue down by reducing the number of links on the Sway Pro. But from a measurement standpoint, the trailer tongue is 2" exactly lower than the ball when standing on it's jack leveled out. That's inline with how Blue Ox says it should be.
View attachment 36913 Just completed a 4630 mile trip out to Yellowstone and back. Avg 9.4 MPG towing an 275BH TT. Traveled 65 on cruise control. absolutely no sway.
I was just under the max weights. We carefully weighed everything we put in the TT. Including the propane tanks and battery. It came out to 550lbs. The TT drywight was 6480. The TT GVWR is 9480. I had it weighed at the cat scale. With everyone in the expy plus full of gas. I was at the following weights
steer axle 3400
Drive axle 4380
Trailer axle 6560
Total axle 14340
have the blue ox WDH.
I have a 2019 platinum max with the HD tow package. Watched the transmission temp. It ran 214. On the entire trip only had one rather steep grade. Where the max transmission temp hit 243 for about 2 min. Then started back down.
Embrace made by cruiser RV. It is a Campers inn exclusive brand.
https://www.cruiserrv.com/2018/travel-trailers/embrace/el-275/
Ok so I found a shank made by blue ox that allows for another 2.5 inches maximum adjustment. So I'll get it and see if that fixes it. I pulled the unit out last night and still has a 1" lift at the front of the trailer even with gear up front. Kind of disappointed that the standard 7 hole shank isn't enough for my Expy. My guess is that if my trailer had a higher ground clearance, I wouldn't be facing this issue.The blue Ox has the same shank.
Great summary @Greg Parker! I’m pulling out for a 5 day river trip with a 30’ KZ Sportsmen borrowed from a friend this Thursday. Looking forward to seeing gas mileage and trans temps during the journey. This will be the first trip near load limit with this rig.
