Boostedbus
Very Nice! Great write up
Pretty big update now Suspension and brakes are wrapped up! Once again, Danny at South Florida Muscle Cars is behind the wrench
Front suspension got a total re-do with new Stiffler's upper and lower control arms. The upper control arms are fully adjustable and allow for proper alignment of a lowered truck, and both the uppers and lowers have the ball joint angle adjusted for a lowered truck. They are also lighter than stock and take some weight off the frontend, before I add it back with the supercharger
The Stiffler's arms do have a 1" drop, so a Energy Suspension 1" lift coil isolator was added to keep ride height the same. (PN 4.6106)
All put together, ran into a slight issue where the supplied endlinks don't have enough threads for the beefy Belltech sway bars.
Danny of course figured out just the trick
This should be the final or near final version of the suspension. Only other changes on the radar are adding rear helper airbags inside the coils, and upgrading the shocks to Bilstein or similar down the road.
So in summary, the suspension setup consists of:
- Belltech 3" drop coils, front and rear
- Belltech swaybars, front and rear
- Belltech street performance shocks, front and rear
- Custom panhard bar by SFMC
- PMT upper and lower trailing arms in the rear
- Stiffler's upper and lower control arms in front
- Energy suspension 1" lift spacers in front
- All polyurethane bushings
- Energy suspension bump stops front and rear
I think I've asked you before, but if not, I'll ask again. Do Stiffler Upper Control Arms fit the 1st Gen 4x4s or just the 4x2s? I'm still looking for adjustable UCA for my '99 4x4 Expy that I lowered using the Ground Force kit.
What's up with the 2 sets of lower control arms?
I like everything but the low stance and front bumper. The OEM stance was better. I think the Expedition looked better original. I am not a fan of the 'aftermarket' look. Some the upgrades seem like overkill.
