Torque converter drain on 4r70w in a 2002 4.6 rwd
0xowner
Western US
I noticed a have a drain hole cover on the torque converter ... From reading, i am under the impression that the real drain plug on this transmission was up to the 2001 models.
I never turned a motor by hand and did I not want to crawl under, out and turn, repeatedly to check.
Does anyone know that if there's a rubber cover then it implies it has the drain plug? Or if the 02 should not have the rubber cover at all if no plug is present? Which may imply I have a replacement trans?
Thanks !
IMINYOURCHAIR
Altoona Alabama
pull the drain cover and confirm which way the engine is supposed to turn and use a rachet on the bolt. or bump the starter via the solenoid to get the drain bolt to line up with the "inspection hole"
0xowner
Western US
I was hoping to see if anyone can say if I should have the plug or not. There is a rubber cover, but I've read that 2002's do not have the drain plug.... I guess then why is there the rubber cover? Did just the torque convertor get updated yet the transmission body not?
I have read that it should turn clockwise while standing in front of engine looking at it.
Also, the rubber cover was missing when I bought it. I have picked one up at the junk yard. Not knowing how long this is been missing and exposing the inside of housing to potential debris and dust, does anyone have a recommendation for what I should inspect or clean just in case some dust that may have gotten up in the housing?
stamp11127
Temple, Georgia
As long as the seals aren't leaking you can install the cover and forget it. Really no need to clean it unless you were in a mud bog.
0xowner
Western US
well, I pushed this maintenance back as the fluid looks decent enough for now. I will concentrate my time on other areas and possibly get back to this within a few thousand miles.
