Tranny temp gauge
Souderton PA
Can anyone recommend an aftermarket temp gauge that plugs into the computer port thingy under the dash? And I believe "computer port thingy" is the technical term used by Ford.:rotflmao:
2000eb
i have a question to go with that sorry its a lil pricey but would be worth it... will the edge cs read tranny temp.... come on all of you with an edge
walnuts4x4
Watertown, NY
yes the edge cs will read... tranny, coolant, engine head, intake temp, volts, % of fuel, % of throttle and many other things as well
panda24619
San Diego
mpg is my favorite thing to watch! go from 11-2.2-65. haha
cruising-wot-down hill 0 throttle.
BakerEdition
EF Chaplain
Trans Temp
I just got my new Edge CS programmer and have had a few days to play with it..it hooks right in the diagnostic port under the dash and you can monitor 8 gauges at once including trans temp. You can set an alarm temp for all of them to if it gets to hot it will sound a alarm to get your attention...I am still working on shift points, pressures and mph. The new trans pan I just put on came with a built in fitting for a trans gauge..but the temp will always be cooler in the bottom of the pan. The pan I just put on was 3" deeper than the factory for a total of 6.5 inches deep and 9 quarts later
DF5.4
Hilton, NY
There are people on an RV forum I'm on that use the ScanGauge to monitor things while towing. I would contact them to see if it will display everything you want.
http://www.scangauge.com/
scottk
VA
Anyone used the Scangauge on an 07+? I am looking at purchasing one to monitor transmission temperature while I am towing
99 Expy
Laramie, WY
Check ebay or craigslist. They might have one you could find a nice deal on
BakerEdition
EF Chaplain
Trans temp monitor
I have the Edge CS and you can monitor up to 8 gauges and trans temp is one of the 8....I have attached 2 photos of what mine looks like with with the truck running...it also has an alarm function you can set for each item monitored and you can set them to what you like...paid 400.00 for this unit of e-bay from jr motorsports...
