Frank Rodriguez
Hi,
I have a 2005 Expedition 4x4. As I pulled into my driveway, I noticed a long trailing drip pattern on the ground. I looked under my truck and there are 2 lines that are SUPER rusted and they are leaking. The one that is leaking the heaviest when the truck is running is connected to the other by a clip before it heads up in the radiator.
There are 2 lines (upper and lower) from what I can tell coming from the side of the radiator. One goes to the bottom of the cooler (I believe) and the other twist and runs back to the middle of the truck to some type of junction box.
Can anyone help me identify these line names/parts so I can purchase OR can I run some type of specialized tubing with compression rings on a job like this?
I appreciate any suggestions.
