tune up
CMBRIAN
fort worth texas
just bought an 04 expo eddie bauer edition , has 150,348 miles on it . i'm wanting to do a tune up on it but not sure what all i should replace. it's running good just not sure if i should do it now or get it looked at by some one first. any help will be appreciated.
BAD RONALD
Fairfield CT
If it's running good, why would you want to spend money on a tune up or having it looked at? Get a code reader and have it ready for when your truck gives you a MIL. Your Expedition will tell you soon enough when it needs attention.
On my '01 I did spark plugs at the regular change interval (COP's while I was at it) and run Lucas Injector Cleaner in a tank of gas every 4,000 miles. Only "tune up" work I ever needed.
There are a bunch of maintenance jobs that could probably use attention if you really want to get busy:
Doing the complete transmission fluid change is a nice thing to do for your truck. Pump out all the fluid using the tranny to do the work, change its filter and consider installing a drain plug in the pan during the job. Total DIY job and highly worth the effort.
Check the coolant condition. Anti freeze change is an often neglected service. Do as complete a change as you know how.
Check the brakes.
Consider changing the differential fluid. (Front too, if applicable)
Just a couple of suggestions off the top of my head and plenty to get started. The point is there's always neglected stuff to work on (read spend $ on) without attempting a tune up when she's already running good for ya.
B
bedrck46
Tune up is always a good idea being you just obtained a used expy unless you have some idea when it was last done. This will give you a base line so you know when it is needed again. Being it is running good at the moment I would suggest that you at least hold off till the weather gets better. Unless you have a heated garage.
Items mentioned by Bad Ronald would be my first items to attend to, and again would give you a good base line for future maintenance
BAD RONALD
Fairfield CT
Absolutely agree. Check the recommended interval change outs for a comprehensive list of tune up items to help you establish this baseline.
