Joey Smith
The 8 thread allocated the appropriate weight to the front. If you add more items in the future, additional adjustments may be needed. Safe travels!
Thx!
Tongue weight is slightly high, around 115 lbs. Is there anything stored in the front of the trailer? If so, move it above the trailer axle. Or go up one hole on the ball.
You can leave the hitch on. It's not heavy enough to make a difference.
How is the handling?
Keep the ball and hitch installed in the truck for calculating the tongue weight.* Those numbers look a lot better to me, and it sounds like tows better, too! The only thing that gives me a little pause is the tongue weight is closer to 11% than the recommended 12-15%. Did you drive it on the interstate with lots of semi trucks and such at relatively high speeds?I ended up going to the cat scale again with my water tank empty, gas tank full and tried tightening up the tension further (almost 9 threads).
Numbers look better based on the feedback provided by people here.
I did have a minor question about how I am measuring the TV only though. Should I be measuring with the hitch ball removed from the TV? I had been leaving it on after disconnecting the TT and just leaving the sway chains and connector with the trailer but I was not removing my hitch ball from the truck (~25 lbs).
My new weights are:
TV Only
Steer Axle: 3140
Drive Axle: 3360
Trailer Axle: 0
Total Axle: 6500
TV + TT (No WDH)
Steer Axle: 2820
Drive Axle: 4300
Trailer Axle: 4900
Total Axle: 12020
TV + TT (8.75 threads)
Steer Axle: 3020
Drive Axle: 4100
Trailer Axle: 4960
Total Axle: 12080
I had been thinking my tongue weight was:
(2820+4300) - 6500 = 620lbs but now I am thinking it should be more like 645lbs if I should have weighed my TV only without the 25lb hitch ball.
I rarely travel with water in the tanks. Sometimes just a small amount so we can pee and flush. But we only camp with hookups because we're in the south and it's hot everywhere nearby. Water is heavy and will definitely change your tongue weight, as will full propane tanks. At 11%, you were at the lower end of that 10 - 15% tongue range before, so the water probably wouldn't push you out of that zone. But watch your payload, as the margins are small when you have a full load.
As an aside, I'm camping in Mora Valley, M right now. I pulled the trailer solo while my wife and daughter drove the car behind (we're leaving the car with my daughter). I drove around 65 - 70 the entire way, but the trailer was very stable up to 75+ when I passed on a couple of occasions. I salute you for trying to get the weights right. It makes a big difference.
