Turn signal problems
chadly
29 Palms, CA
Ive been searching a little and narrowed my problem down. Heres what happens: Left turn signal on - rear one blinks really fast - front stays solid.
I thinks its either the bulb since they are dual fillament, or the MFS. I will switch out the bulbs first. They are clear bulbs anyway and I dont like the way the light up white with the clear lenses.
If its not the bulbs, is the MFS the only other thing it could be?
C
chadly
29 Palms, CA
I figured out if I tilt the wheel up one notch everything works fine, so thats my temporary fix. Hope this helps someone out in the future.
JUST4FUN
Admin
Moderator Administrator
Il
MFS is going out get a new one and change it
smo0othride
San Diego, CA
What is the MFS? One of my blinkers started blinking really fast for awhile, but then the problem just went away on its own after about a year...
JUST4FUN
Admin
Il
multi function switch or turn sig switch
sparro
ca
replacing multifunction switch on exp '99
Does anyone know how to remove the steering column cover top piece? I had no problem remving the bottom piece by turning 3 screws at the bottom. But I am lost as to how I could remove the top, in order to get to the MFS.
sparro
ca
turn signal problem on my exp 99
i finally replaced my multifunction switch. still, my turn signal does not work. everything else on the switch works.
please help!!!
ELVATO
Orlando, FL
Could it be the flasher?
It still does this with stock bulbs, I'm guessing?
Smooth, when a blinker start flashing rapidly, it usually means you have a bulb out, or at least one of the filaments is out.
