twernst
MiddKid - Any follow-up on this?
I have the same problem, although I think it is a CarPlay issue. Occasionally (maybe 1 in 5 times?), when I plug my iPhone in, CarPlay does not launch, and the charge cycles on and off. If I go into the settings and disable CarPlay, the cycling stops and the phone charges as normal. Related: the same instances in which this occurs, I get a "no GPS" indication on my native navigation (see photo below). And just as you said, its a trip-long issue....if it works when I try the first time, I have no problem, if it doesn't, it's not going to work for the entire ride.
I'm thinking there is some miscommunication between the car and the phone. The car thinks I want to run CarPlay but one of the devices is dropping the ball. So one of them (I think the car) keeps trying to establish the connection (hence the power cycling). This jives with the fact that the problem resolves when I disable CarPlay in the center stack because the car no longer tries to make the connection. My guess would be the "no GPS" indication is because the system thinks I'm running CarPlay so it's relying on the phone's GPS...but the phone wont connect.
It's clearly not a cable/hardware issue because it charges perfectly when I disable CarPlay. My question is, I guess, is this a CarPlay software gremlin or a Sync software gremlin?
In any case, I am very interested to know if you ever got resolution with your dealer. Thanks!!!View attachment 24133
I have issues like this at times, sometimes I think I "fix" them by turning off the Bluetooth on the phone and only having it connect via the USB. But my current vehicle does no have Apple Car play but can play music from phone/movies through the USB connection. Has anyone tried truing off the Bluetooth and then seeing if the car play work. I know my suggestion may seem silly, but grasping at straws.
