What did you do to your expedition today?
hooraah
West Palm, FL
SKF is the best in the world. Period. If you bought some for less than $2 each, I would keep an eye on them. ;)
Good point. I realized that the lowest bidder on a bearing probably isn't giving me the highest quality part, but then what would I get in a reman pulley from duralast/dayco? From the Ford dealer? Its hard to say unless you're in the supply chain, but its definitely not an SKF because the bearing itself is more than the whole pulley from the auto parts store.
If this were my every day truck, I might be more discerning with parts, but this thing is a beater. The bearings that came out had a little grind to them when you spun them but didn't wobble at all after probably 200k miles. These bearings run smooth, but may not stay that way for long. Who knows? I suspect the bearings I put in are better than what came out, and for a truck I drive maybe 1k miles/year thats good enough for me. Maybe I should make that more explicit when telling other people how to do it.
I don't want you to think I'm arguing with you too hard, I appreciate the advice especially from someone with industry experience. I'm actually in engineering myself but in my field we have people dedicated to only doing bearings so I don't see too much of that.
hooraah
West Palm, FL
I wonder if it makes sense to either score/marr the outer bearing or the inside of the pulley, slightly crease/dimple the pulley ID on either side of the bearing, or use adhesive of some kind as a preventative measure. I know...:facepalm: but this kind of backward thinking has got through life a lot if years.
Just read this... I may try it: "When you go to replace the bearing, freeze the bearing (overnight) and throw the pulley in the oven(hour at 450*). Then press it in."
I wouldn't worry about that. You'll see when you get the bearing in the pulley and see how tight it is you'll see why you don't need to do that.
As far as heating/cooling, yes, thats a common method of assisting press fits, but I don't know that I'd want to work with something that hot. Maybe freeze the bearing and heat the pulley up to 200F or so, otherwise you're going to have to try to maneuver the pulley into your vice using tongs or similar.
SHAGGYS EXPO
NC
Replaced my transfer case starter motor. UGH. Sounded easy. But pulling all those wires out the clip and transferig them were fun fun. Waiting for new radiator. Had the side busy out on me. JB welded it together. And a pin hole popped out. So just gonna replace her.
l3l4k0ut
iowa
vacuumed out, wiped down every interior surface. cleaned out all my junk in the console (coins, old receipts) needed it bad :) now its clean, no gunk, no crap. oh n i changed the oil too. motorcraft filter.
QbanCgar
Hagerstown, MD
i plan on doing this tomorrow...MUCH needed!
BrandonB
Kansas
This was yesterday -- broke a cam cap bolt off :/ Today I ordered a replacement and a few more and am picking up left handed drill bits to try to fix my boo boo.
SHAGGYS EXPO
NC
Anyone able to give some advice on putting 35s under a 98 EB. what have u used. Have already swapped out the air ride kit.
I
IMINYOURCHAIR
Altoona Alabama
I've had a wheel speed vibration since I got new tires. had them rotated and balanced today but the vibration seemed to move with the tires. I lifted the front end up to spin the tires to check for roundness issues. I think that they were mounted wrong as there seems to be a flat spot on both tires. (both are brand new but have about 400 miles on them) I will try another store since I have free rotate balance for life of tires if they can't resolve it I will pay an independent shop to re mount them for me.
BrandonB
Kansas
Kinda cold this morning and the ground was wet so didn't get as much done as I wanted. I went and got it tagged so that's out of the way. Also stopped by and borrowed an engine lift, bought some chain and took the alternator off to use it's bolts to mount the chain too.
Tomorrows task - unhook motor mounts, lift engine, drop oil pan and clean the pan and pickup tube/screen.
mlself
