Whats the verdict on XLT/Limited LED head light upgrade?
ETC13
TN
Here is the direct reply of bulbs from Alla for this application:
Low Beam H11 bulb size >> https://allalighting.com/shop/produ...Headlight-Bulbs-for-Cars-Trucks-|-1-Pair/5018
*low chance of requiring extra load resistors*
High Beam 9005 bulb size >> https://allalighting.com/shop/produ...Headlight-Bulbs-for-Cars-Trucks-|-1-Pair/5020
Fog Light 9140/H10 bulb size >>https://allalighting.com/shop/produ...Bright-LED-Lights-Bulbs-for-Cars,-Trucks/4434
Front Turn Signal 7444 bulb size >> https://allalighting.com/shop/produ...n-Signal-Light-|-Super-Bright-LED-|1-Pair/563
Rear Turn Signal 3157 bulb size >> https://allalighting.com/shop/produ...-Turn-Reverse-Tail-Lights-Bulbs-|-1-Pair/2669
*will require extra load resistors*
Brake Light/ Tail Light 3157 bulb size >> https://allalighting.com/shop/produ...-Turn-Reverse-Tail-Lights-Bulbs-|-1-Pair/2669
*may require extra load resistors*
Reverse Light 3157 bulb size >>https://allalighting.com/shop/produ...-Turn-Reverse-Tail-Lights-Bulbs-|-1-Pair/2669
Universal Load Resistors >>https://allalighting.com/shop/produ...gnal-Hyper-Flash-Error-Canceller-|-1-Pair/375
For the applications not listed we will require an image of original bulb part number. Based on owner’s manual the application would have stock LED bulbs and if so our LED products would not be compatible.
Sent from my moto g(7) using Tapatalk
DenSanAZ
Arizona
Yes, the model listed for the fogs fit with no issue. Ordered mine off of Amazon and yes it says they don't fit. I contacted Alla lighting before ordering.
I'm interested in replacing my bulbs as well. I just bought my '18 Expedition and the headlights are the one thing that I don't like. Are these bulbs easy to switch out? I can figure out how to access them, once in the housing, do the old bulbs just pull out and the new ones push in? Or is there a trick? Also, do you know if the fog lamps are available in yellow? The Switchback turn lamps, is that just for the front or does it work in the back as well? I know, lots of questions - thanks for your help!
DenSanAZ
Arizona
Oops, I just saw your post for the other vehicle lights, so the turn-signal question is answered!
ETC13
TN
Install video for the low beams. Highs are the same just right below the lows. Note you don't have to take out the main clip like they do. Just the front panel screws.
Fog install (plenty of clearance with the bulbs I listened):
ETC13
TN
Looks like Alla has moved their commerce all over to Amazon now.
https://www.amazon.com/allalighting?ref_=d6k_applink_bb_dls
LyoddChrissmiss
Cincinnati
Hi, I’m a new owner to a 2020 Expy XLT blacked out edition. I have a 2000 Expy many moons ago and have since been an Explorer owner
Anyways , I’ve been scouring the posts on Led fog bulbs for the 4th gen Expedition. So I purchased some Alla H11. Got them and they did not fit. So I then ordered from Amazon again, and got some JDM H11 LEDs. They didn’t fit. I took a closer look at the oem bulb and it’s a Phillips H8. I just ordered Alla H8 so I’m hoping it will fit.
im wondering if the 2020’s have a different bulb set up on the fogs?
I hope I don’t run into this when I do the high/low beams.
utmeep
The fogs are the only difference. The manual is incorrect and was never corrected by Ford.
LyoddChrissmiss
Cincinnati
Ok to update all information I have received on what bulbs are in my Expeditions front are incorrect.
As mention earlier the fog light bulbs ended up being H8’s
So today I pulled the low beam, manuals again indicated it to being H11. I got in there to install a new slyvania silver star ultra. It ended up being 9005...Lucky for me Auto Zone allowed me to exchange even after package was opened. Installed the new 9005 and fit is perfect.
While up there I pulled the High beam. Those were H9’s. Not HB3’s as everyone says.
I don’t know why or what’s up but Ford changed the bulbs during build. The Expy is brand new with 400 miles which I got from the dealer with 11. Built in March 2020.
utmeep
Seems like you may have it flipped, top bulb is low and bottom is high? H9 are similar to H11 and 9005 are similar to HB3 as they have the same connectors. I have a Feb 2020 build XLT Fx4 and the only thing wrong was the fog bulb.
PaulMedik
