What's going one everyone! I'm Henry 30 living just outside of Chicago.
It needs the following:
Brakes all around (rotors & pads)-FIXED
Rear wiper motor
Fogs don't engage so troubleshoot wiring-FIXED
Horrible misfire situation going on-FIXED
O2 sensors-FIXED
A new front diff as it no longer operating in 4x4 and it's not the switch as I checked. -FIXED
Right turn signal doesn't work in front even with new bulb (troubleshoot) FIXED
Tie rods and ball joints need replacing-FIXED
Power steering is none existent in this truck FIXED
It's sagging at the rear end even though it doesn't have air suspension FIXED
Oil contaminated with coolant hardcore FIXED
E-brake cable is broke at the center FIXED
Cat converter has a hole right down the middle of it FIXED
Oil pan is dented like a **** FIXED
Cam phaser, sounds like a diesel -FIXED
Needs new tires cause right now they're like drag radials-FIXED
Needs a speintine belt and both idler pullies, a tensioner assembly, power steering and crank pills replaced. FIXED
And finally none of the interior lights works. FIXED
top 3 hardest repairs (and I mean a giant PITA) were
1. Cam phaser (I think that was the hardest job I ever made)
2. Head gasket
3. Rear shocks/struts
Rear wiper motor
O2 sensors-FIXED
2. Head gasket
