sjwhiteley
True dat. Probably why you see so many Escalades repossessed.They're mostly mortgaged.....
The thing is, you have nothing else to compare it to. If you would have changed the oil with let's say plain old Valvoline at every 5,500 miles and pulled it apart you would still see the original cross hatcheswith zero visible wear.The vehicles I bought new are still owned and no plans to get rid of. Oil and filter changes every 3,000. The '16 Expy regardless of the oil monitor 3,000 with Motorcraft Semi synth... it has turbos and tight oil passages. So far I have pulled apart the '85 Mustang, '89 and 95 F350...zero cylinder wear, so no one can ever convince me that changing the oil "too soon" is a waste.
And you'll be just fine doing that. You would also be fine changing at 7,000 with mobil 1. If you did some research and reading up on it though you'd probably switch from mobile one unless you using the extended performance. Mobil 1 isn't as good as it used to be but it's still a good synthetic oil just not one of the top-tier fully synthetic oils.I change my oil every 3,000 miles no matter what and I use Mobil 1.
It also affects how you maintain your vehicle. When you buy it and expect to keep it long term, you do the little things extra. But most seem to be of the mindset that they are just dumping theirs in a few years and starting a new mortgage.
I bought a case of oil filters for mine, so I'll be dumping it often. I do a lot of short trips, so moisture builds up in my oil, especially in winter.
