Foy57
Gentlemen,
I just today signed the paperwork to purchase a 1999 Expedition XLT, 5.4, 4WD, 4R100 automatic, 3 row seating, 131,000 miles. Appears to be a solid unit--no tailpipe coating or smell of burning oil, full power, smooth-shifting 4R100, very smooth ride, good brakes, etc. Known issues are on again-off again low output heater (partially plugged-up heater core since the dealer's flush improved it some), flickering odometer, non-working rear glass wiper, some rust on the lower trailing arms. I'm figuring on the following immediate maintenance/service and would be grateful for any comments or suggestions:
Oil and filter change--I see the 5.4 capacity is 6.0 qts and that 5W-30 is recommended. Wondering if 10W-40 might be more appropriate with the miles on the 5.4 and the hot summer weather we have here in NC.
ATF change--The ATF is a very pale pink and while it doesn't smell burnt, it doesn't smell like new, clean ATF. My intuition says do a full system flush/refill, change the internal filter, and install a Magnefine in-line filter (if there is already a segment of rubber line within the cooling circuit). Despite the extra expense, I'd consider Mobil 1 full synthetic, which is what I've been running in my F350's 4R100. The '02 Superduty has 232,000 miles now and the 4R100 has never been gone in to, so I am high on the synthetic.
Front and rear diffs fluids changed--full synthetic gear fluid
Transfer case fluid change- full synthetic ATF
Cooling system flush--thinking maybe an aggressive flush now that the heater core is flowing at least partially may help break up the funk in there and buy some time for a heater core replacement. The truck has front and rear A/C and heat, w/ registers on both floor and panels. Does this truck have a second heater core for the rear unit? If so, is the second core alongside the first one? Any suggestions as to a particular cooling system flush-out chemical system much appreciated.
I'm seeing reference to one-row and two-row radiators. I suppose it's easy enough to look-see which I have, correct?
Replace air filter and PCV filter.
Replace fuel filter--looks as though some sort of fuel filter tool is required--correct?
Speaking of special tools, will I need a heater hose puller to get access to the heater core nipples?
Chassis lube--I'm not seeing zerks in the front suspension at the ball joints, control arms, etc. What chassis lube points should I be looking for?
The transmission selector lever is somewhat stiff and it moves between gears with a bit of difficulty. From reading here, I get the idea the cable gets bound up in its casing and may need to be replaced at some point. I don't suppose there's a ready way to lube the cable, is there?
This truck will be a daily driver for my son's 20 mile round-trip in-town commute and a weekender for him, his bride, and our first grandchild, due in March. I of course want it to be as right and safe as is possible, so any other suggestions much appreciated.
Foy
Foy
