northernexp
- Joined
- Nov 5, 2013
- Posts
- 274
- Reaction score
- 38
I got the oil pan back on today with a fresh new gasket, I cleaned the mating surfaces and the entire pan inside and out, then hit it with a coat of high temp paint, some of the original paint was disappearing around the drain hole and I wanted to coat it before rust starts.
Also drained the transmission, dropped the pan and changed out the filter. The pan was stamped letting me know that the gasket was re usable. Normally I would have changed it anyways but the gasket that came with the ATP kit was a paper gasket compared to the oem rubber with steel gasket, and the oem gasket wasn't leaking so I cleaned it up and re installed the pan.
I hit both pan flanges with permatex high tack liquid gasket, it really holds onto the gaskets well and adds a little extra insurance against leaking, I don't use it on the block or transmission.
I did however use permatex high heat gasket sealer at each corner of the block where seams are.
I drained and filled the front diff and the transfer case, I did the rear diff a year ago and only drove for 5 months on it so it should be good still.
I went ahead and changed the serpentine belt and the fuel filter, finishing off my maintenance list.
I haven't added oil yet, I'm waiting until the gasket sealer has 24 hours to fully cure before I let oil touch it, I'm really looking forward to going for a drive tomorrow!!
Sent from my SGH-I337M using Tapatalk
