got 2 370 alts fabbed up on the truck...air intake isn't what i pictured would be made for the truck but for now it seems to work... Will have to go to a shop to have the air flow rate figured out compared to what it needs to be
The 370 alt on the motor is putting me at 15.2v which it is handling well... only aggravating thing is the alt regulator is wired to bypass the pcm and is causing my charging light to stay on throwing a code... the fix is to send the alt back for them to rewire the regulator and add the middle pin and wire for the pcm to recognize the alt is there to stop throwing the code... but I can't do that for a while
Motor alt has a double pulley which the fan shop welded together... if anything happens to the other alts I'll be able to disconnect without having to be without the truck cuz it's own belt system
Sent from my SAMSUNG-SM-G935A using Tapatalk
