Hampton, VA
i did this today...lol
Irwin
Found a sweet deal on some 50% Tread Life BFG ATs
Finally running on 285s that are load rated.
Canadian Expy
Toronto ON
I replaced upper control arm + ball joint, then put in dual batteries and new alt.
Then fuse block and wired everything up.
Ohh also LED lights in the interior :favorites37:
FireRed5.4
Changed the #3 COP... Was having an intermittent engine miss and loss of power after overnight rain (AGAIN) hooked up the ODB and #3 was the culprit. When I pulled it there was moisture around the top of the boot, I must be parking on just the right angle for the rain water to drip in the plug hole. The Heater control Valve is also located just above it.
alaskanexpy
anchorage alaska
had somebody highbeam be this morning after making a lane change with plenty of room. which pissed me off, so i delt with any future idiots that may do the same.
they are pretty damn bright!
Big White
Upstate NY
I hope you are kidding.
You could seriously cause someone to wipe out doing that. And even that not happening, everyone has a cell phone. I would certainly call 911 and follow until LEO shows up.
