indcolts18288
I have an '04 and its the low beam. Replaced the bulb and when I plugged it all in the bulb started smoking and smelled like burning plastic. Any advice greatly appreciated
If it came from the lamp itself its a bad bulb. If it came from the socket area check and make sure the electrical contacts are in good shape.
make sure the lights are off when replacing
Did you touch the bulb when putting it on? But I would agree with what toms said. Also, if you get a new bulb, it helps to wipe them down with alcohol to make sure you get any residue off.
