Truck Goes Straight To high Beams and fog lights don't work
YoungKraze
CHICAGO IL
My 1998 Ford Expo Is Acting up I turn on my lights and it goes to high beams (How do they turn on) And then try to pull the Fog Lights And they don't turn on? Help already got a warning For driving with high beams
B
bedrck46
did you recently change the multi function switch
when did this start happening and what did you change recently
sounds like you may have a problem with the main light switch
B
bedrck46
sounds like you did something wrong recheck your connections and look to see if any pins got bent or broken or maybe you didn't push the connector in all the way.
Y
YoungKraze
CHICAGO IL
i will but how do you turn on the high beams anywasy Recently bought the expo in january
B
bedrck46
do you have an owners manual if not go to
owner.ford.com
and download a copy read it and you will get a wealth of information on how to operate all the controls, switches etc.
B
bedrck46
now if you already got a warning for driving with High Beams it would appear that you know how to turn them on. In you first post you stated your problem But it would have been nice of you to have mentioned that your problem occurred after you did the work you done It would help others to know where and when your problem started
Y
YoungKraze
CHICAGO IL
I didn't Really Think it matter but my High Beams just turn on randomly And 3 Days ago I got a warning From a cop so yesterday I tried to Figure out how to turn them on but could not figure out! Feeling Like an idiot I replaced the Fuse today And still nothing and the bulbs are in great shape
FordandPolaris
Saint Cloud, MN
Agreed, push the turn signal switch away from you to engage high beams, pull it towards you to return to normal. You can go from the middle beam position and pull it towards you to momentarily engage high beams until you release the stalk.
Honestly check to see if the turn signal stalk is pushed forward before you tear it back off.
Y
YoungKraze
CHICAGO IL
I Did Already It's We're it's supposed to be I moved it around but the High beams wouldn't Turn off? Might be buying New Bulbs tomorrow Probably Upgrade To HID Lights See if that helps
B
bedrck46
you should get the lights working properly first before thinking new HID Lights will help
splintrcel
Milwaukee
Knowing how to activate high beams is important. Fog lights will not turn on with high beams on.
BAD RONALD
Fairfield CT
Absolutely correct.
It makes no sense to think that replacing the headlights would correct this problem. It is unlikely that the low beams on both cooked at the same time. Moreover, it is probable that the work done caused the malfunction. If the OP refuses to follow this reasoning, future repair work on his EXPEDITION is gonna be EXPENSIVE.
Y
YoungKraze
CHICAGO IL
Thanks everyone But the problen was a wire ripped or must have touched something cause it broek but taped it with electrical tape now waiting for weather to be good and soder wire
B
bedrck46
Thanks for the update Now you can upgrade to your idea about HID lights
