B
bedrck46
pull fuse #8 in the fuse box under dash and then check that pk/bk wire to see if it still has power to it
Does it have power at all times or just when the key is in the run/start position
If you follow A,B,C and E on the prints you will see they go in different directions and thru different connectors although they flash at the same time which is due to the switch position but either left or right, front or back the voltage travels on different paths
