The ecoboost engine does have some nice enhancements over traditional engines. The power is produces for it's size is certainty impressive. I hate to admit it because I too favor the v8, but the turbo charged smaller displacement engines are more efficient in most ways. I wonder how progress is going on the cvvt (constantly variable valve train) development. That's really going to be another major jump for engines and efficiency/power.
To answer your question about the valve-train, the 3.5 EcoBoost V-6 uses
twin independent-variable camshaft timing (Ti-VCT) and a dual over head cam (DOHC) setup with 24-valves, 4-valves per cylinder with 2 intake and 2 exhaust valves per cylinder.
Intelligent Ti-VCT is employed to control the timing of the 12 intake and 12 exhaust valves. Ti-VCT accomplishes this by adjusting both intake camshaft phasing to continuously adjust the intake vales, and exhaust camshaft phasing to continuously adjust the exhaust valves.
The Ti-VCT system operates by applying hydraulic pressure in a sealed Ti-VCT unit (there are two of them) to move the rotor vane (which is bolted to the corresponding camshaft) from an advance position, to a retard position, or vice versa.
Fuel is injected into the cylinder chambers by direct injectors mounted to the underside of the chamber head and protrude into the distal edge of the compression chamber.
All this allows the pumped-up V-6 to breathe freely, and make the most out of every drop of fuel spent during combustion. But that still doesn’t scratch the surface of the advanced V-6 which also uses air-to-air intercooled twin-turbochargers which can work comfortably with operating temperatures up to 954 degrees Celsius or about 1,750 degrees Fahrenheit.
