I just took delivery of my 2018 Expedition Limited MAX this morning and by noon, I was already playing around with FORScan. Here is what I have found works so far.
Everything listed below has been confirmed working. If you find something you think is of interest that you have confirmed working, please feel free to add it here so we can build a google doc of all the available modifications.
Here is what I've come up with so far:
At this time, whenever I try to write anything to the IPC or DDM/PDM, I receive a "Service procedure has been interrupted." error so I will be sending log files to the FORScan people to see if they can resolve the issue.
Code:
BdyCM 726-41-02 xxx0 xxxx xxxx Disable No Key Present Double Honk
BdyCM 726-27-01 xxxx xxx0 xxxx Enable Fogs On w/ LED headlamps
BdyCM 726-48-02 x0xx xxxx xxxx Disable Auto Start Stop
APIM 7D0-01-01 xxxx xxxx xExx Enable On-Screen H/C Seat Buttons
APIM 7D0-01-01 9xxx xxxx xxxx Disable Sirius As Audio Source
APIM 7D0-02-01 5753 xxxx xxxx Data Entry While Vehicle Moving
