Close but not the same. Once the brakes are applied at a stop light, Auto Hold continues to apply the brakes indefinitely so long as it's enabled, the doors are closed and the driver seatbelt is fastened.
Okay, I guess I don't see the need for it.Close but not the same. Once the brakes are applied at a stop light, Auto Hold continues to apply the brakes indefinitely so long as it's enabled, the doors are closed and the driver seatbelt is fastened.
So true about keyless entry, my wife’s 09 fit doesn’t have it and I couldn’t believe they still made cars without it when we met in 2011.If auto start stop has not been deactivated and the brake pedal is depressed enough for the auto hold to engage, the engine will shut off like a regular stop and the brakes will continue to hold the vehicle the same as if you were holding them.
I know plenty of people that find it an unnecessary feature until they’ve used it for a while. Kind of like remote keyless entry. Anyone that grew up inserting a key into a lock cylinder to unlock a vehicle was used to it and didn’t think twice about it then but has become used to RKE enough nowadays that most wouldn’t buy a vehicle without.
Still getting the feel of my 2018 Expedition. Disabling auto stop start sounds good. Still figuring out on drive mode preferences.
One of my frustrations so far is with the 360 degree camera which I love!
Hate that once on, by going in reverse or pushing the button it goes off so easily, as when going from "R" to "D" forward. Would like it to stay on for a set time or better still until a higher vehicle speed is reached. Still want to see where I am in forward as well as reverse for tight situations. The button is a long reach...
Unless I'm missing some user setting, wonder if anyone knows or figures out a
FORScan Mod that could change this behavior??
So you go and buy a $70,000 truck and already you’re reconfiguring bcm’s? Why not just buy a fancy Denali?I just took delivery of my 2018 Expedition Limited MAX this morning and by noon, I was already playing around with FORScan. Here is what I have found works so far.
Everything listed below has been confirmed working. If you find something you think is of interest that you have confirmed working, please feel free to add it here so we can build a google doc of all the available modifications.
Here is what I've come up with so far:
Code:BdyCM 726-41-02 xxx0 xxxx xxxx Disable No Key Present Double Honk BdyCM 726-27-01 xxxx xxx0 xxxx Enable Fogs On w/ LED headlamps BdyCM 726-48-02 x0xx xxxx xxxx Disable Auto Start Stop APIM 7D0-01-01 xxxx xxxx xExx Enable On-Screen H/C Seat Buttons APIM 7D0-01-01 9xxx xxxx xxxx Disable Sirius As Audio Source APIM 7D0-02-01 5753 xxxx xxxx Data Entry While Vehicle Moving
At this time, whenever I try to write anything to the IPC or DDM/PDM, I receive a "Service procedure has been interrupted." error so I will be sending log files to the FORScan people to see if they can resolve the issue.
