ForScan Tweaks - 2015+
East-TN
Air Force
TN
In the general forum an interesting question came up. Enabling TPMS as a display gauge on 2017. They linked a video of it being done on a Fusion. I know different modules but interesting.
A couple of forum members have tried, but no discovery so far of how to make it show on Instrument Cluster.
East-TN
Air Force
TN
Line 11 is for the front Hyper flash there is one for the rear hyperflash. 726-14-01 is for the rear.
What is the difference between two double horn honk lines? We show 726-16-01 as the line that works on the spreadsheet link that @AllBoostNoEco posted but you show a 726-41-01.
Andy, I updated the spreadsheet to clarify the Hyper Flash.
The two different codes are for the 2015-2017 Expy and the 2018 Expy...different line for the new Expy.
Take a look at the spreadsheet now to see if my changes took.
https://docs.google.com/spreadsheets/d/1iO4Uz1shNRwZv5gi2TKARDo2Y7lfSOMFj6Gott8g7yg/edit?usp=sharing
Axle Folly
Seattle Area
Both front and rear hyperflash are in the spreadsheet from @17LimitedExpy.
I am curious if the "Drive-In" stereo duration can be extended to 120+ minutes if we continue to increase that character, maybe up to F?
ExpeditionAndy
Fort Wayne, Indiana
17, a couple of thoughts. put the 2018 stuff on a separate tab so we don't confuse people.
What is the Drive Ratio line all about? Is that also for a 2018?
I would probably put the two hyperflash codes together one below the other. It will make it easier for someone looking for those changes.
Other than that, good job.
East-TN
Air Force
TN
Just to clarify...are you going to make the changes, or are you asking me to make the changes with your inputs?
ExpeditionAndy
Fort Wayne, Indiana
I don't think I have the rights to write to the spreadsheet. All I can do is view it and download it. So I think you would have to make the changes if you like my suggestions. I'm not sure if there is anything else on there that is for the 2018 Expedition but is probably best put on a separate tab.
East-TN
Air Force
TN
Have you collected any other changes I can add to the spreadsheet?
AllBoostNoEco
GA
I have the rights to make changes to the spreadsheet, just haven’t really had any time to make the updates that have been found. @ads245 originally made it, but I haven’t seen him post in quite a while.
If @17LimitedExpy builds a new one I will try and transfer over the changes so there’s multiple versions floating around. Just have to find space in the little free time I have working 80+ hours a week.
East-TN
Air Force
TN
No reason to kill yourself rushing...I’m retired with ‘extra’ hours on my hands, so happy to compile the data. Give me a couple of days and I’ll post what I’ve collected.
We all benefit when we gather the data/info together.
Moderator
What he said. Not doable. We are missing the modules. Same reason we can’t do the HVAC on the right side MFD. Not a matter of finding the function...we are missing the module capable of it.
mossback
2017 Limited EL
WA state
On that note, I think that Secure Idle is also not doable on any expy prior to 2018. I would love to be wrong about that, but it seems like a dead end based on the research of others as well as all avenues I have pursued.
One other thought. While I have no verification, I think 2018 Expy owners should check either the current Explorer or F150 FORScan spreadsheets as I'm guessing most and maybe all of the parameters are transferable/applicable to the '18s.
East-TN
Air Force
TN
Update on my remote start. Finally made it down to Home Depot to get them cut. They did it for free...perks of being a woman. Made the changes in ForScan, and followed the instructions on this video:
I now have remote start...factory, not aftermarket. When I purchased my Expy they told me it would be an aftermarket install that was going to run $1000. My total cost, less than $100...for keys and Scantool OBDLink MX Bluetooth.
Have done some additional modes like DRL, Bambi Mode, Seatbelt chime off, Keys in ignition off, horn off on lock. Try to see what else might be fun to add.
Thanks for all those that have contributed to this thread as it has been a huge help.
Which FORScan line did you change to enable remote start?
East-TN
Air Force
TN
Here are the codes for the F150. It may work on the expedition
Double Horn Honk disable BCM 726-41-02 xxx0 xxxx xxxx
Essentially in the BCM in 726-41-02 you change the 4th number of first set of numbers to zero and save it.
Andy - you asked me about this earlier...I mistook your post to say this worked on the newer Expys. Do you know anymore about this line...is it confirmed to work on your 2017 or the 2018s?
Thanks.
East-TN
Air Force
TN
Drove 200 miles today just to be able to try this. No luck getting the option to be available in the IPC (yet), but changing 726-49-01 did the magic. The checkmark is gone. I am unable to physically verify they are in fact off, because my truck doesn't have any headlights. But I consider that a good sign.
As I'm going through this thread to gather/verify FORScan codes...this DRL option on the left side of the instrument cluster came up...any progress on this?
NOTE: In the Mustang community it takes 4 lines of BCM (or BdyCM) code change to permit full control of the DRL options on the left screen:
726-16-02 x1x1 x1x1 x1xx
726-21-01 xxxx xxxx x1xx
726-50-01 04xx
720-02-01 xx?x xxxx xxxx (change ? to C if previous was 8, or add 4 to value if not 8)
ExpeditionAndy
Fort Wayne, Indiana
Thanks.
This is in the other spreadsheet Line 23. I assume it works and I know several who said they used it. The double honk doesn't worry me because I never leave the vehicle unattended while running.
East-TN
Air Force
TN
Ok, but you haven't tried it or verified it worked...correct?
East-TN
Air Force
TN
East-TN
Air Force
TN
Here’s a couple of pics for the Engineer Test mode...allows you to see several screens of data.
2ACF3AEA-9C3E-42B1-9D1C-14A34AC21DFD.jpeg CBAEDD56-65FA-4DB5-8599-B20526FED8A2.jpeg 6C5395ED-3861-47F3-9F77-8A9273A389E0.jpeg
