17LimitedExpy
I just took delivery of my 2018 Expedition Limited MAX this morning and by noon, I was already playing around with FORScan. Here is what I have found works so far.
Everything listed below has been confirmed working. If you find something you think is of interest that you have confirmed working, please feel free to add it here so we can build a google doc of all the available modifications.
Here is what I've come up with so far:
Code:BdyCM 726-41-02 xxx0 xxxx xxxx Disable No Key Present Double Honk BdyCM 726-27-01 xxxx xxx0 xxxx Enable Fogs On w/ LED headlamps BdyCM 726-48-02 x0xx xxxx xxxx Disable Auto Start Stop APIM 7D0-01-01 xxxx xxxx xExx Enable On-Screen H/C Seat Buttons APIM 7D0-01-01 9xxx xxxx xxxx Disable Sirius As Audio Source APIM 7D0-02-01 5753 xxxx xxxx Data Entry While Vehicle Moving
At this time, whenever I try to write anything to the IPC or DDM/PDM, I receive a "Service procedure has been interrupted." error so I will be sending log files to the FORScan people to see if they can resolve the issue.
@rcompart...did you change 4 bits for the Navigation in Motion line on the APIM (7D0-02-01)...or did you change the line to the following:
7D0-02-01 x7xx xxxx xxxx
Any other 2018 FORScan changes you've uncovered? It looks like the 2018 Expy is almost line-for-line the same as the 2015-2018 F150 codes...is this what you are finding?
Thanks.
