ABS and TC lights on.
On my way into work this morning I thought I smelled my brakes burning up, didn't think much of it. I got again in to drive to Home Depot a few minuets ago and my ABS light is on and my message center is telling me there is an AdvanceTrac TC System Fault. Again I smell burning brakes.... any idea? I'm hoping just a sensor.
It's also acting very strange, I feel every vibration in the road and its loud in the rear.... sounds like a wheel bearing about to give but obviously not the issue.
J Ski
3.5plati
VA
Locked caliper?
As of last the truck locked itself out of Traction control and turned it off itself, no more smell or resistance but still noisy.
Big Brian
Farmington Hills Mi
wheel bearing
mine did the same thing
mine was right rear. Scan for codes it will point you to the correct wheel
jack up the truck one wheel at a time and rock it feel for looseness
The abs sensor senses that something is wrong when the sensor teeth on the hub moves away from the sensor, triggers the abs light, then the traction control light
I never did hear anything like a wheel bearing noise, but it was loose
Yea stopped at autozone while I was out and about code says wheel bearing
you actually had a code for a wheel bearing? Did not know there was one
It was the "frequently reported fix" for the code which was to replace the wheel bearing.
Skip to 4:10 these same lights I had too, he uses a blue driver that actually tells him it's the wheel bearing. Same situation.
Just jacked it up passenger side rear has WAY too much play for comfort. My questsion is at this point should I replace both rears? Holy cow the axle nut is RUSTY.
Big Brian
Farmington Hills Mi
You could I did not I am waiting until it goes
If you dont have an acetylene torch take it to someone who does because you will never get it apart without one. An air hammer helps too
the axle nut is the easy part
I also bought a Timken hub with the abs sensor already on it if you need it its another $80 might as well get the whole ball of wax
My dad does HVAC and refrigeration and has acetylene and oxygen/acetylene torches, I'll probably bring it over to my parents house and have my dad help with the fun. He likes keeping busy anyway lol.
Genuine Ford Parts replacements are $172/ piece on rock auto I think I'll order two, Napa wanted. $200 for aftermarket.
Big Brian
Farmington Hills Mi
ok thats good with the torch it will be pretty easy. You will need it for the 4 bolts that hold the hub onto the knuckle. Heat the hub where the bolts screw in until cherry red, then they will come right out A air hammer is good to get the hub off the knuckle, mine was so rusted on that it would not budge, I had to take the parking brake off so I was able to access the hub to heat it for the bolts, and then I hit it with the air hammer on the side, then it popped right off
I tried a big slide hammer on it and it laughed at it
Once you take the parking brake shoes off its a lot easier to deal with , I tried with leaving them on but ended up taking them off and the whole job was a lot easier
I found the best deal on the hub on Amazon, it was about $160 free shipping no tax that was for the Timken hub with the sensor
bobmbx
Oof. Thats misleading. Its not telling you that the bearing is bad. Its telling you the ABS sensor is bad, and the fix is to replace the hub assembly. Thats because its a sealed unit and it contains both the bearing and the sensor.
I don't think it's really misleading. The wheel bearing has a lot of play and clunks back and forth when I jacked the truck up and pull on the wheel. I've heard a very slight noise from the rear that aggravates when turning for a few weeks now. From what I gather when the bearing goes bad and shakes the sensor faults and sends a code on through?
Instead of continuing to throw money at this thing you should go buy that new GM you been talking about :)
Hehe I can't afford a brand new one, maybe a 2015-16. Remember talk is cheap ;). I throw money at em till there down for the count, (Motor or tranny). Probably will be the next venture though, by then it may be a 2018 model year or whatever is lightly used then.
