Airbag light on 2008 Expedition XLT
bobmbx
Does anybody know what the OHMS reading for the DriverSide Airbag is? I noticed something in my mobile forscan app..
Pass Airbag reads 2 ohms
Driver Airbag reads 26 ohms
that seems WAY off...this kinda supports my theory that the airbag is bad?
2-4 ohms is in the normal range; I've read that a bad squib (open) will read ~25 ohms, not zero.
R
Rob Adams
Medford, OR
Can you elaborate on the "bad squib" thing? what is that? Something inside the airbag or is that in the clockspring? I called up my local ford stealer-ship and they said 139 for the diagnostic.
bobmbx
The short explanation:
A squib is small explosive charge that initiates a larger explosive charge. Its basically a fuze that explodes. In the airbag, its what those wires are connected to.
R
Rob Adams
Medford, OR
OK so It sounds like I need to bite the bullet and run through the pinpoint test to narrow this down at this point. I found a guide to build a 2ohm airbag test adapter to rule out the airbag itself.
I don't "think" it's the clockspring as the horn and cruise control work but at this point I'm just going to have to start ruling things out.
1955moose
Sounds like you should do 2 things. #1, get a repair CD for your vehicle, and #2, read up on all precautions to not somehow activate the airbag. That would not be pretty. Your dealing with an explosion type device, you need to know how it detanates, or more importantly, how not to.
R
Rob Adams
Medford, OR
The airbag itself is completely disconnected and out of the vehicle. I'm not concerned about detonating it at this point. I have extensively read on how to de-power and properly remove airbag components. I consider myself a fairly versed shade tree Ford tech, However I do appreciate your concern regarding that. I am definitely in the more advanced repair/troubleshooting stages with this and will use the utmost caution.
I can test the circuit using a 2Ohm resistor plugged into where the airbag goes ultimately tricking the computer into thinking the airbag is plugged in and functioning (pretty standard hack for modders who change steering wheels and seats) Tf the harness, clockspring, etc is good the computer should read back ~2-4 ohms and therefore would indicate the airbag itself is bad. If no change it's likely something in the wiring harness/RCM. Currently the circuit reads 26 ohms so thats definitely not right.
1955moose
Sorry Rob, wasn't questioning your mechanic skills, it's just that in 4 plus years on the forum, I haven't seen an air bag issue, and wanted you to be safe. I myself don't have the specs you'll need for your troubleshooting of the air bag system. I'm sure one of our electrical system experts can or will chime in with diagnostic procedure. Good luck, as always follow up with your findings.
R
Rob Adams
Medford, OR
OH no problem. I really do appreciate you bothering to take the time to caution me! You can never be too careful with the airbag system. I just didn't want anyone to think I was just going in and doing things without careful planning. Fords are a passion of mine and I keep a fleet of family trucks running. At times I feel I should have not gone into it but instead been a certified Ford mechanic! However I'm not above asking for help and taking direction. The people on this forum have been hugely helpful! :)
1955moose
Their should be a troubleshooting procedure on all data, if you don't want to buy the Ford repair CD. If one of your shop buddies will let you use his/her computer with their account. If not eBay people sell the CD for under $20.00.
R
Rob Adams
Medford, OR
Bit of a bonehead mistake I made last night while troubleshooting my wiring harness...I dropped the Transceiver piece that reads the key chip and it exploded all over the garage floor...damn those things are fragile...I packed all the fine antenna wire back in the device in hope that it would just work but to no avail and now the truck won't start due to the PATS system thinking I tampered with the transceiver. Shop manual says I "shouldnt" have to reprogram the PATS as its just the transceiver that reads the key chip. Stealership wants 45 bucks for the part so thats not too bad. downside is that none have the part in stock and no wrecking yards have my generation expedition to go scavenge. Guess I'm kinda SOL for now.
Flexpedition
midwest
6E5Z-15607-AA is the part number. Its on Amazon for a little less, free shipping, but not 2-day prime. Looks like it'll come out of Amarillo, TX.
https://www.amazon.com/Ford-6E5Z-15...&qid=1546627005&sr=8-1&keywords=6E5Z-15607-AA
If you click on the "New (9) from $39.75" link, you'll see Sound Ford in Renton (Seattle) Washington lists one - maybe they can get it to you quicker?
Taska's website lists other vehicles that they claim this part interchanges with - includes F150, Mustang and Super Duty:
https://www.tascaparts.com/oem-parts/ford-ignition-immobilizer-module-6e5z15607aa
Some ebay listings show it also interchanges with the previous generation Fusion (2012 & backwards)
R
Rob Adams
Medford, OR
So my part number is slightly different 6e5t-15607-ac but yes this looks like a part that should be a simple fix. Just wish my dealer had it in stock so that I could grab it and get this truck started again.
1955moose
Deep down, your like me, never fall into that category, and end up fixing it ourselves. If your suspecting your airbag, see if dealer has one in stock that will let you do your ohm measurements. When in doubt, that's what I've done with electrical parts. Problem will be, do they have one in stock.
R
Rob Adams
Medford, OR
So I definitely have a bad clockspring. Cruise control and horn stopped working today. I bet you it's the source of my airbag light too. New part on order here Tuesday
1955moose
A delayed reaction. It's funny how a part works one day fine like your horn, and throws your diagnostic off on the airbag. Hope that's your problem. The recall for the airbags is at a minimum 2010. A huge recall for Ford, over a million vehicles.
R
Rob Adams
Medford, OR
Yeah, I sure hope this makes the light go off...it would make sense. However if it doesn't I guess I have 2 paths forward...take it to Ford and have them do the 139 dollar diagnostic/pinpoint test for me...or try and source an airbag to test in place of the current one. Clockspring arrives tuesday and will post an update then.
1955moose
Well, see what happens, maybe you can pick the brains of shops and dealers in your area. That's what I've done when stuck, just be nice!
