How to add remote start using forscan
mquick5
Buckeye Country
Old post but has anyone with an Ssv model expedition done this? Just wanting to make sure it will work before spending any money on it
Only money you'd be out is for the key fobs and obd adapter. Which are both handy to have anyways. What year is your Ssv?
Sent from my Bristol motor speedway using Tapatalk
Parkspremier
Oregon
It’s a 2015, so I guess I’m still just a little confused on what exactly the Forscan is. It would possibly just be the key fobs and an obsessed adapter but what runs the program? A separate tuner or a computer etc?
Moderator
Computer. There is a FORSCAN Area here. Go do a little reading. Read the beginning of the long one started by me. That will get you the basics you need to get started.
Langer
Chicago
I know many have chimed in saying they’ve activated remote start using forscan and with the keys that were linked on amazon, just wanted to share my success, as well. For whatever reason it takes “lock + 3 clicks of the remote start button” but she starts, nonetheless. Thanks again!
mquick5
Buckeye Country
Good to hear. I'm tempted to try lock 3X's on my original fobs to see if they will start it.
Still not sure about the climate settings. Summer will be here soon, if it automatically runs high cold ac from the vents, I won't have nothing to worry about.
Langer
Chicago
I was just going to ask if you had any luck adjusting the startup climate settings. Keep us posted if you find anything.
Dabbill
Spokane, WA
Can you use the ForScan phone app for modifications or is that only for reading codes? I do not own a Windows or Apple laptop. All my computers are Linux. Any one tried to run this software in WINE?
Moderator
The Mobile app does not do any programming.
Does not run very well via Wine last I heard. I would not trust it. You are trusting a conversion program to program a module on your vehicle. You could possibly use Virtual Box and a Windows VM. I know people have gotten VM to work on Mac’s.
There is an actual FORScan Forum on FORScan’s site. There might be better help for that there.
Dabbill
Spokane, WA
Thanks. I work in IT and have ~25 VMs running on my home server. I was just hoping that I would not have to go that route if I didn't have to.
Black
Kentucky
A barebones $150 windows laptop or tablet will run ForScan easily and well worth the cost to be able to actually utilize ForScan.
Heck may even find something at a pawn shop for under $100.
Moderator
As do I. Have all OS’s running around my house! MacBook Pro is my primary laptop, Precision Workstation for VM creation on customer sites, and I use my old Latitude 7250 as my programming laptop. Like Black said, the Dell/Best Buy special will cut it just fine. Does not need to be powerful, just portable. I use an HPTuner MPVI2 as my Tuning device, and I need a laptop for that also. So it serves for all of my vehicle needs.
mquick5
Buckeye Country
I tried my original key fobs, they will not start the truck, no matter how many times I hit lock.
As far as the AC goes, it will run if the temp is set to cold. The fan speed can be off, but as long as the temp is set to cold I get high ac from vents. If set to heat, I get high defrost. So nothing to adjust here.
Expy00
Does anyone know if the number of keys is limited on the 2017 Expedition?
I realize this is a mature thread but my question is related to this topic so I will start here rather than start a new thread. '
My keys have been cut, I have the listing for REMOTE START in ForScan and was ready to start. The Locksmith that cut the keys told some of the Fords (at least the older models he was not sure if it appl nied to the 2017 models) had a limit on the number of keys that can operate remotely. He thought only four could operate remotely and only 8 could be set to start the car.
When I got the Expy it only had one key. I purchased two more and programmed using ForeScan. So there are currently four keys though I only have three. I want to add the two for remote start.
He also said if the new keys do not operate the locks, cycle the ON-OFF 8 times to delete the remote program then depress the lock button on the four keys I want to use. I have of course read of the requirement to cycle ON-OFF 8 times make the remote start function but there was no mention of that procedure erasing the program for the other remotes.
What do you think? I am a little reluctant to start, now.
6 Sept 19 EDIT: I got one key to program the buttons and now have remote start. What the locksmith told me was not quite correct for my car. Cycling ON-OFF eight (8) times did not erase all the key's button programs. It only seemed to program the key in use.
6 Sept 19 SECOND EDIT: I tried the second key about a dozen times today and finally got it to program. Then, just to make sure, I tried Key no 1 again and it did not unlock the doors or start the engine. So I tried the ON-OFF cycling again and this time did press the lock button on each of the four keys and now they all unlock the doors and both new keys operate REMOTE START. Hurray!
Langer
Chicago
Sorry, I know this is old, @mquick5 , but for me it was hitting the remote start button 3 times (despite the button saying 2 times), not the lock button multiple times.
RogerD1959
2.5 Months Ltr, and Final Bill 22K+
Fond du Lac, WI United States
I think the max number of FORD blessed and baptized smart keys, like the one in the photo, you can have per vehicle is Six (6). More than that the dealership looks at you, "Funny," like your up to something, or no good. Still want more than 6 smart keys. Well cause I occassionally have to much time on my hands, often a story to tell, drop me a shout and I'll send the rest of this one. 86e39a82e4fe2cd9a11cb73a4a8854c9.jpgb520d5b715bc266d37f2fb88bb5554eb.jpg
Sent from my SM-G950U1 using Tapatalk
Expy00
So I tried to program and set up REMOTE START on my 2017 Expedition EL XLT.
The remote tart feature did appear in the menu items in plain English in FORscan. The Remote Start parking light option was not there.
I first added the 2 new remote start keys using the FORD procedure. Both keys started the vehicle but none of the buttons initiated their functions.
I thought it may be due to the four (4) keys limit for remote functions. (There were already 4 keys set up but I did not receive one from the dealer).
I then erased all the keys using FORscan and re-programmed the two remote start keys and two others. I still could not get the buttons to work on the to remote start keys.
Somewhere along the line I got no key to start the vehicle and had to erase and reprogram keys.
I am now left no worse or better than when I started. Three keys work the doors and a five keys start the truck.
Some of the times the procedure of turning ignition ON-OFF eight times did operate the door locks indicating I was in program mode for the remote buttons, but the two new remote keys never enable their functions.
I guess my conclusion is the keys I bought don't have functioning buttons.
Let me know you think of anything else to try.
Expy00
mquick5
Buckeye Country
Expy00
There's 2 different steps to programming keys. One for ignition, and for fob buttons. I posted on this earlier in this thread. From memory I had to turn key on and off 8 X's. See post #25 & 26...
Langer
Chicago
It took me a few tries to get the fobs all programmed, too. I would advise persistence.
Expy00
Thanks for the m'quick response....
Yes I tried cycling ON-OFF eight times based on your previous post. The first few times there was a double door lock or something like that I figured I was in the programming mode for the buttons, but none of them ever worked.
Expy00
I was able to get one of keys programmed and now "the wife" has REMOTE START. She was so happy :)
She wants to know what else can I do with FORscan!
