jaketime81
Update, I found the fix: 2018+ found a dsp module, code 783-01-01 and changed ****-xxxx to Cxxx-xxxx.
-Jake
-Jake
Just want to confirm this method does work. I have a 2018 Limited that I just programmed to do this on. Neither of my mirrors tilted at all when I tried the first time. I did notice my passenger side mirror flicker or click like it wanted to move but it never tilted down. My first attempt was on the driver side and it didn't work at all. It just saved the setting in the down position and never went back. I went to try the passenger side with the same instructions from above and it worked. Then when I clicked back to the drivers side, it worked as well.
A little odd but it did finally work. Only thing I hate is that you have to hit the button to get it to lower. It doesn't automatically do it when you put the car in reverse. I'm wondering if there is an override for this in FORSCAN so it will automatically tilt when in reverse without hitting the button?
-Jake
Has anyone been able to figure out how to disable the chime when you first start the car? The codes on the spreadsheet cannot be applied on the 2018 platform.
What are the locations for the fake engine noise and what are the settings?Got my cable from Amazon and my extended license from FORScan and as a complete novice was able to:
Disable Auto Start/Stop
Disable double horn honk when I step out vehicle with FOB
Disabled fake engine noise,
(I want to hear the real engine noises and get used to it so
when something isn’t right I can hear it right
away)
Panic Alarm now requires two pushes of the panic button, (Kept going off in my pocket)
All of these functions should be programmable from the driver’s menu IMHO but FORScan did the job for me.
