How to optimize MPG - thoughts?
Charlie Lohr
Seattle
I have a 2019 XLT w/Tow Package (non max). With the factory tires I was getting 14.7 MPG combine highway/city. I have since put on 275/70/18 (which look awesome BTW and fit stock on factory rims with no rubbing) and I am still getting around 14.7. I give the back story to say the tires didn’t have a hug impact but I knew that wouldn’t help.
What I would like to know is what can be done to optimize my gas mileage so I am getting the best distance for my buck. Below is my initial thoughts but would love to know others thoughts as well.
-premium full (one test tank MPG was 16.5 but driving conditions where favorable)
-Eco mode (I typically use it)
-synthetic oil??
-Good tire pressure (running at 50 psi now)
-others??
grumpyoleman
flyover country
Driving habits would be the biggest impact. Wifey's '18 Max is getting 17.5 in mixed but she drives very conservatively. Average goes down noticeably the rare times I get to drive.
Her = Eco
Him = Boost
Can't have both at the same time.
That being said, if you are driving conservatively, then your MPG does sound low.
John JJW
Baja, CA,MX
Drove from San Felipe to Mexicali, Baja, Mx. 2019 FX4 w/ HD tow package. Cruise set at 65mph, roundtrip 23mpg. I get 20 average with mixed driving. We do not have ethanol in the fuel here, so that helps. Around town I coast to a stop, instead of using brakes, no jack rabbit starts.
Plati
-synthetic oil??
-others??
Premium gas? Run the numbers but probably costs more overall than regular due to higher per gallon cost offsetting and mpg increase
Don't think synthetic oil buys you additional mpg, don't have facts on that but IMHO
Running at 50psi wrong thing to do unless you have E rated LT tires. Less safe and bad wear pattern on tires. Isnt that above the tire rating on P tires?
You bought an expensive vehicle. You obviously can afford the gas and aren't concerned about carbon emission (which is fine with me). Drive and enjoy.
Less boost more eco
Others. Drive like there is a raw egg between your foot & gas pedal. Don't let car idle too long before driving.
NyackRob79
Nyack, NY
If you bought a 6,000-lb truck for fuel economy, you probably bought it for the wrong reasons. MPG will fluctuate due to driving habits, type of driving, etc. 14-17mpg in city/urban areas seems fair. We average about 15 in the city, 21 on highway.
Deadman
You need to try and feather the gas as much as possible. On starts, take off easy, and then let off way before you need brakes and try not to apply brakes if you can coast and still maintain a safe speed (someone turning in front of you). The cruise control kills at least 2 full MPG on mine. Every hill it goes down, its slamming on brakes or downshifting or whatever it does to scrub speed and thats all wasted fuel. Coast down every hill, accelerate on the way down the hill and let is slow down on the way up the next hill, etc.
I've got a 4x4 Tow Pack Max and I drove it very conservatively on a 120 mile round trip and it would make 25.5 mpg on non ethanol premium fuel going 60-62 mph on mostly all highway with a few stops and passing a few slower cars. It wasn't a fun drive, but it was an economical drive. I wanted to test it, so I knew what it was capable of.
Mines life average mpg right now is 18.3 mpg and it gets a lot of idle time waiting to pick my kids up from school and stuff. Idle kills mpg because you are averaging ZERO into your average.
In town, mine sucks fuel and drops to like 15mpg, so don't expect to do real well in town unless you can find a better way! lol
Rancidlunchmeat
2019 XLT FX4
I drive normally, little differently than I did in my GT and I'm get just over 17mpg mixed after 800 miles. 2019 FX4. I don't think you need to be overly conservative to get that level of MPG, but I do think that driving aggressively even infrequently will severely reduce your MPG quick fast and in a hurry.
Gumby
Beaumont, Alberta
Wheel weight is obviously a factor. Those 22's weigh a lot. I would be curious what the weight of your 18's vs the 22's are. Also, just use premium. You get the "benefit" of all those horses...
JasonH
Houston, TX
The tire pressure is too high at 50 unless actively towing. I know because I tow and left the pressure high in between trips. The center of tread is wearing faster than the edges, handling was worse, and the ride quality suffered.
Accelerate slowly
Coast and avoid stop and go as much as possible
Keep the revs down
Keep the speed down
I'm switching to EVs for my other cars to offset gas and maintenance on Expedition.
C
Charlie Lohr
Seattle
Thank you for all the replys. To follow up on the tire pressure, I am running E rated tires. It was strange that my gas mileage didn't drop with the heavier tires (it was already low and I am sure the tow package gear ratio helps at lower speeds). I am taking it into the dealer for some other warranty work so I am going to have them run some test and see what they come up with. Also I know I bought a heavy full size SUV and not a hybrid but that doesn't mean you can try to optimize gas mileage to min. the overall impact of the vehicle. Also, similar to JasonH, I am buying an EV for the commuter car.
Fozzy
Riverton
Here is a different take on driving style. I have a buddy that has had the EcoBoost’s since the beginning and is now in the new 10 speed F-150. He swears by this and I have found it to work pretty good as well. He says use the Boost part to get the truck up to speed. You don’t have to hammer down and drive like a A-hole, but get on it. No easy soft acceleration. Get to speed quickly. If you watch the boost gauge even slowly accelerating raises the boost gauge which equals poor fuel mileage. Once to speed back out and let the the Eco part keep it at speed. I have 35” E tires and a safari rack. Tow package in a Max and live in Utah where there is not much flat driving. I get 19 MPH average highway and 15-16 MPH city driving this way. Not the best, but if I lug it around it gets 13 city and 16 highway. I do run premium. Same with my F-150 with the 6 speed Eco. 6 speed pickup vs 10 speed SUV MPG is almost identical. Truck does have 3:55’s. Kinda like the 6 speed better.
Soliyou
OK
This is exactly what I do! Excellent advice.
Get yourself moving up to Speed pretty fast (no hammering down) then drive off boost till the next red light. Basically the engine will be Almost idling at 1000 - 1200 rpm on 40-50 mph. With this I get 17-18 mpg in city driving.
I also go slightly above the speed limit to get a higher gear then slow down to the limit and the transmission usually holds the higher gear.
Without these tricks I get 14-15 mpg
keny01998
Arkansas
I average around 16 mpg city and 18 mixed. Just took a 500 miles road trip, cruised at 75 mph and I got 22 mpg. Pretty impressive for this truck. It has the same mpg as my 2010 MDX with premium gas.
David Kuchler
Reno, NV
Post is alittle old to be responding but maybe you are still watching and wondering.
All vehicles, to optimize fuel economy.
paying attention far beyond the car in front of you
never accelerate more than the max speed to be achieved, meaning when you hit the freeway slowly pushing gas pedal down, to point that will end in the speed you hope to achieve
I use cruise control from in 30 mph speed zones all the way to freeway driving, using coast and accel when required to minimize any use of gas pedal, I can drive from reno nv to san fransisco ca, 240 miles, never touching gas or brake, best case
coming off freeway, I click cruise off, 1/4 to 1/2 mile prior to offramp, and coast to a stop, never using brake when ever possible, every second coasting counts
maintain tire pressures, regular oil changes with recommended oil, synthetic or regular oil
I find so much peace in driving my own race daily, never finding myself in that mass of cars going to and from my destinations, very relaxing, and yes occasionally you have those drivers literally pushing you along (tail gater) I don't car every mile I drive im putting money in my pocket
last, I will at times literally turn my vehicle off on those 4 minute lights around town, idling kills mileage on average 1/10 every minute
Coast Coast Coast, will save you huge on brake jobs as well
Cruise control whenever possible, consistency is everything
accelerate, no more than required with a gentle touch, theres another light in a 1000 ft anyway 9 times out of ten
Nautique220
Burbank
‘19 Platinum 4x4 with tow package here...850 miles on the odometer. My wife mostly drives city and we are averaging less than 14MPG. My 2017 Tahoe averaged 16.5MPG.
Hoping to get up to the same when the engine breaks in.
Wayne Decker
New York State
With 6500 miles on my Platinum with the tow package I'm getting 19-20, except when I'm pulling a 6,600 lb Airstream, then it's 9-10.
This is better by a few mpg than my Hemi Durango did. But the Hemi got 10-12 towing. I'm still way ahead of the game as towing is only 20% of my driving.
dlcorbett
Air Force
tx
-synthetic oil??
-others??
You need to break the engine in. Once the break in period is reached, your mpg will increase dramatically. I went from barely getting 20mpg hwy to doin 23+ on the hwy at 70ish mph. Im avg about 18 lifetime wchich is pretty good as spirt gets addicting sometimes.
Fozzy
Riverton
At what mileage number is that at? I just turned 3K and haven’t seen any improvement. Thanks.
