4th Gen Expy FORScan Modifications
Molaf
Merica
I never did get it to work. I just switched it back and have waited to hear if someone else figured it out. It’s my wife’s vehicle and it doesn’t bother her, so I just hit the button whenever I drive it.
So apparently that error message is because it disables the Battery Management System as well.
sjwhiteley
Kentucky
I found that the Hyperflash settings for the 3rd gen (it already had zeroes in those spots) do not work for the 4th gen (2019). I had top use the F150 FORscan locations to eliminate the hyperflash.
726-27-01 x0xx xxxx xxxx Front Bulb Outage (0=disable)
726-27-02 xxxx xxxx x0xx Rear Bulb Outage (0=disable)
There is a 'humanly readable' setting for the 'Double Honk while leaving with the key', as well as 'bambi mode' - so those are very easy to change, in version 2.3.28 beta.
Lou Hamilton
I'm about to buy the ODBLink MX+.
I don't really have a working Windows laptop. Will I still be able to make changes with my iPad and the iOS ForScan Lite app? Or do I need the full Windows version?
I want to make sure I can do what I want to before buying anything.
Thanks in advance!
Lou Hamilton
So, I quickly changes the SYNC 3 theme to Lincoln, but wanted the splashscreen to remain Ford, not Lincoln.
However, even with the splashscreen changed to the default Ford one, it shows the Lincoln. Thoughts?
7D0-01-02 8xxx xxxx xxxx -- Lincoln Setting
7D0-02-01 xxxx x1xx xxxx -- Default Ford splashscreen
7D0-03-01 xxxx x3xx xxxx -- New Lincoln Theme
Lou Hamilton
Correction...
Boot splash screen is correct.
It is the splash screen that shows when the system is shutting down that remains as the Lincoln one. Anyone know of a second setting to correct this?
techdude99
US
I'm new to Ford with a '19 Expedition Platinum Max and I'm glad I found this thread.
I'd love to change the engine auto stop and get the LCD screen to go back to Android Auto after adjusting the seats.
From what I've read, making changes will cause errors. I'll be monitoring the discussion for a solution.
Molaf
Merica
Anyone know the defaults values for re-enabling stop start? I backed everything, but don't want to erase everything else. Appreciate the help in advance.
Greco
Saint Johns
Hi, New to the blog.
My Exped XLT 2019 has now "remote start" after installing the perimeter plus but I still trying to figure out the APIM changes I need to make in order to get the remote settings on the dash display.
Has anybody successfully identified this parameter? I will really appreciate any help.
jgudnason
Calgary, Ab, Canada
Hey Hey,
downloaded the most recent version of Forscan, and finally i am able to write values to the IPC!!! woot woot two years later.
now have temperatures showing on the cluster (720-07-01 *** xE5x xxxx)
and i also toggled on the forward distance alert feature (720-01-02 xxxx-Nxxx) haven't driven with that yet, but i was able to toggle it on in the menu after that change. (in my case, toggled 7 to B)
always annoyed me it was a feature in the user manual, but not enabled on the vehicle.
savbraze
