Ready Lift 3-2 kit installed with CCD suspension
Dakota4ce
South Dakota
The farther you get from 90°, the quicker more sporadic the reading change is going to be back to the computer. It’s as if you were going from a bumpy road to a washboard road.
All I’m trying to do is get the sensors back to the original engineered factory design operating location and range.
You certainly might get by cheating it, just remember; you can cheat on your wife too, but it’s not recommended and typically has a consequence or two....:D
Yes agree—but you had mentioned it’s designed to be at 90. I was just pointing out it cannot get to 90 at all per the bracket interference.
How much longer do the links end up being after the lift is installed? Anyone know?
Miekk
Madison Lake, MN
Front ones need to be shorter and the rears need to be longer than the factory 4” center-to-center. I know they don’t change the same amount because the sensors aren’t the same distance from the A-arm pivots. Only feedback I’ve ever gotten were estimates. Attached are pictures of front and rear factory setups. Sensor arms are pretty close to 90. AE72C416-5B36-49D3-9D7B-30BDDE4B63CE.jpeg7D071B2C-8065-485D-88D6-C86A7D012655.jpeg
Dakota4ce
South Dakota
Got it. So it really doesn’t matter what the specific length is as long as it is somewhat close to
90° at rest.
michman0969
Rochester, Michigan
90° at rest.
My two cents: avoid any potential errors because know one really knows what the true issues could be... I would highly recommend to use his adjustable links and match the arms angle to exactly where they were when you start. Use the angle finder on the measure app on your iphone and set the angle right back and you will have no worry at all! Just did mine a week ago. I apologize if my opinion is unwarranted.
Sent from my iPhone using Tapatalk1453debe27b9388fca805b4a76df134d.jpg31082914d5347e86ffd6267431d9aded.jpg
michman0969
Rochester, Michigan
Front ones need to be shorter and the rears need to be longer than the factory 4” center-to-center. I know they don’t change the same amount because the sensors aren’t the same distance from the A-arm pivots. Only feedback I’ve ever gotten were estimates. Attached are pictures of front and rear factory setups. Sensor arms are pretty close to 90. View attachment 34099View attachment 34100
Miekk, you were a real gentleman when I talked to you on the phone from Michigan and everything you said was right on during our convo. I found that I did not have to switch the left to the right on the struts though I considered it. After a close study of the differences of doing it vs not. I just had a tiny reroute of the solenoid wire from the strut and honestly that was no problem at all. Few zip ties and done. Thank you for making em! Dave D
Dakota4ce
South Dakota
Ordered a set. You should have seen the ebay auction this evening....I am just over in Sioux Falls.
Hey, thanks to everyone who’s using these. My 17 and 15 yr olds thank you also. It helps support their snowmobiling and motorcycling addictions. :)
Dakota4ce
South Dakota
Too all those who have done this and have added the adjustable links, do you happen to know the length you ended up with on the new links? I have the lift installed already.
If the measurement isn't able to be gotten, may just make them so that the sensor arm is around 90 degrees and call it good.
Thoughts welcomed!
Tyler Makeig
Picked up the wife's new Stealth Expedition Limited today and installed a 3-2 lift on it pretty much immediately. Yes, I know that this isn't supposed to work. Yes I know ReadyLift says it won't work, but it works. Here's what we did:
Before starting we measured each wheel well and recorded it. I don't have the numbers in front of me, but in the end the lift was NOT 3 in the front or 2 in the back.
Next, we used the iPhone measure app to take an angle measurement on each CCD sensor. We then recorded what we had in order to replicate the factory angles with new adjustable arms from this source:
CCD Brackets: 507-381-4260
Once we had our measurements, we put the truck on lift, pulled the wheels off and got to work.
On the front, we found that the electronic solenoid on the shock was clocked differently once the spacers were attached. I believe we could have fixed this by swapping the left and right shocks, but by the time this occurred to us we had the front buttoned up and were not inclined to undo everything and start from scratch. We did have to fashion a tool from right angle bar stock to attach to the lower ball joint after it was removed from the lower control arm. With a block of wood to take up the gap, we used this as a secure way to leverage the lower control arm down so that the strut assembly could be installed. In the end, the CCD wiring had to be slightly re-routed due to the solenoids being 180 degrees out of their original location, but there appear to be no clearance issues. Still, if you plan on doing this, just plan on switching the left and right shocks out for each other once the spacers are installed.
On the rear, we found that the two spacers each needed one of the lower mounting holes modified because the welds were too long and prevented the nuts from tightening flush to the flange. Easy fix, but be prepared for it. We chose to disconnect the CCD arms, then remove the inside lower control arm bolt as well as the lower shock bolt. This allowed the assembly to drop down enough for the shock / spring assembly to be removed easily. The top 3 nuts holding the shock to the frame mount were NOT as easy as the front ones were. In particular the inside two (especially passenger side due to the fuel lines) were a huge pain in the ass. The installation was straight forward, however, but since the CCD is not supposed to be lifted, no mention was made of the CCD solenoid. While re-installing the first one, we discovered the problem with the solenoid clocked 180 degrees out, so we swapped sides and sure enough everything went back together easily. We just tightened the bolts, settled the suspension, and torqued to spec.
Once the truck was back on the ground we installed the adjustable arms and adjusted them until each sensor was at the same angle as stock. Both front arms required approximately 3/4" of thread to be removed in order to achieve the desired angle, whereas the rear arms required nothing more than adjustment. I found that each complete revolution equaled roughly 1 degree, maybe that will help someone from having to take it on and off as many times as I did.
A quick test drive to check the install and no problems or faults were noted. No warnings from the message center, and the ride was exactly as it had been before. Fantastic.
Tomorrow the wheels and tires will be switched, and I'll see if the offset I got will allow me to push the envelope with 34" tires. If not, we have 33s standing by.....
In the end, this kit DID NOT give me the lift I was hoping for. Up front I netted just over 2" and out back I gained about 1.75" This left me still with a noticeable rake to the front, but I'm hopeful that it will settle some with use and at least be level.
FYI the front spacers (22-6615) that they claim to be the "3" in the 3-2 lift are labeled 2.25" level lift for F150. Yes I confirmed with Ready Lift that this was in fact the correct part for this kit.
All in all this was not difficult so if you are holding off because you have the CCD suspension, DON'T.
Pics tomorrow with the tires. It's late and I need another beer.
Ed
I was intending to update what i went through when installing my lift on the CCD given the advice published here I just hadnt got to it yet. Now I have an issue and am hoping to get some advice from others who have a lift installed on CCD and or caution those who are thinking about it.
As for the front, I attempted to switch the lh and rh struts but no matter which way i rotated it i could not get the upper mount to line up aswell as the lower mounting points. i spent a good hour just trying different orientations thinking I was doing something wrong and I decided to move forward without switching the shocks. when the car was on a hoist there did not seem to be any clearance issues.
As for the rear switching the shocks did work as described and caused no issue.
So, lift was done, all was well and good, no driving issues. I was stoked on it!
My wife took the car to the dealer for our free oil change. and they informed her that the cv boots were torn...
as soon as she got back i crawled under there and sure enough.. those solenoids were rubbing on the cv boots and tore both front boots.
I have to find a solution to this issue, I am too deep in this one to go back to stock..
anyway, if anyone has experience with this I would appreciate input. and if you think all is well with your CCD lift.... I suggest you take a look at the cv boots where the axle goes through the knuckle.
Tyler Makeig
Hello all! I've been a lurker on this thread for a while, but I found the thread really helpful, so I thought I would post a picture of my wife's ride after the lift install. I installed the Readylift 3/2 on a 2019 Stealth Edition with CCD suspension. On the front struts, we used a spring compressor to allow us to loosen and rotate the top flange 180 degrees to fix the issue regarding the electronic solenoids on the struts, and avoid reinstalling the strut with the solenoids facing out. On the rear we simply swapped the left and right side struts after the lift spacers where installed. Following the OP, we used the iPhone measurement tool and installed the adjustable sensor position arms following his advice. Finally, we used 1.25" BORA wheel spacers (does require trimming the studs, but nothing to be afraid of...) which allowed for a 325/50R22 (roughly 34.5" x 12.8" R22) tire after a little trimming of the fender well. We also trimmed the automatic running boards 3" on each side, although I'm not positive this was necessary at all, and certainly 3" was not, but it looks fine. To trim them, remove them from the truck, use a chop saw to cut, and replace the plastic end cap.
THIS! is what I was looking for, looks like im in store for another fun weekend of suspension teardown.
Fozzy
Riverton
I just looked underneath mine and we didn’t switch strut side to side and nothings even close to the CV boot...?
What clock position would you say your Solenoid is in. 3 o’clock would be the tire 9 would be towards the frame and inner CV or anywhere between.
StealthyBulldog
Manitoba Canada
Well, thought I had the Mrs talked into the lift (thanks to showing her pics of all your rides!) but it seems to be a no after talking with my dealer. I asked him about warranty if I added the lift, he said "well, anything that would be affected by the lift would no longer be covered" Well I bought a new vehicle to HAVE warranty, so I guess I won't be nulling it 3 months in. Too bad, it looks great with a couple extra inches
Dakota4ce
South Dakota
Except, nothing would be affected by the lift.....mine said the same thing as they are required to respond in that manner. However, I don't really place a lot of stock into that sentence. There is really no component that will be stressed by the spacers.
And, I had 2 hubs replaced under warranty on my 16 with a lift and 35s on it. Not a word was mentioned.
TBaganATX
Buda
Ready lift 3/2 worked great with the adjustable CCD links from ebay!
My end result was nearly on at an after measurement of 2.75 inch front and 1.75on rear.
from my iPhone using Tapatalk664ca2f63f70aae19a916ba0e1200aea.jpg952dad57094378cb9963881874e0f0f4.jpg
This looks sick!
StealthyBulldog
Manitoba Canada
I'm in agreement with you, unfortunately, my dealer isn't! Since I'm in a small town with only one Ford dealer, doesn't give me much for options. I might try chatting with the service manager, Although I suppose the man whose name is on the sign has a little more say in the matter.
Dakota4ce
South Dakota
What I’m saying is, even though they say that, you’ll never experience an issue that can be blamed on the suspension lift.
Lou Hamilton
I talked to a local company about adding the ReadyLift to mine. I told them about Miekk's adapters in conjunction with the lift kit.
They are supposed to e-mail me some information this week. In response, they want me to send the link to the sensor parts and then possibly reach out to him to see what they are all about if not clear to them. Probably going with Nitto Ridge Grappler tires no matter what; just playing with sizes.
If I keep it a stock height and use stock wheels, I think i have three tire size options -- 285/45, 285/50, 305/45 -- understanding that two of them will need spacers to properly clear the UCA.
With the lift, I might try to go with the 285/55's to get a little more side wall.
Granted, this still needs to pass the WAF and probably won't be until sometime over the summer. ;)
