stamp11127
Temple, Georgia
Current Issues:
No Crank No Start - key in start position causes click in trailer-tow relay.
No communication to PCM from OBD2.
No power to fuel pump unless relay bypassed.
Gear selector won’t release when key on/brake pressed.
Instrument cluster will not illuminate.
Turn signals not working - flashers DO work.
HVAC panel has no power.
Which one do you want to work on next? I'll need the wiring diagrams for what you choose.
stamp11127
Temple, Georgia
Continuity setting is the first yellow one to the right of 200 ohms resistance.
Be careful with that meter "10A max unfused" means it burns/explodes if overloaded.
03NavigatorGuy
03NavigatorGuy
Memphis TN
Yes, Thanks, I lent my good one to my brother, haven't gotten it back yet!
I will now let the dumb questions begin!
In checking the continuity of the of the ignition switch, am I to test from the switch to the CJB or where?
stamp11127
Temple, Georgia
Switch disconnected. Testing input/output at the switch:
pin 4 to 7 in start
pin 4 to 6 in accessory and run
pin 4 to 1 in run and start
Each test should tone when the circuit path is good. Any that fails means a bad switch.
03NavigatorGuy
03NavigatorGuy
Memphis TN
pin 4 to 7 in start
They all appear to have power as required.
stamp11127
Temple, Georgia
Then you don't need another ignition switch. They are not supposed to have power during the test, just continuity.
The continuity test is a resistance test, under a specific threshold of resistance you will get a tone from your meter. Above the threshold you will get no tone but a measurement of resistance. This test requires the circuit being tested to be unpowered - the meter provides the power. Try running a continuity test on a high voltage circuit with power present is a recipe for disaster.
You can add a replacement wire from pin 7 at the ignition switch plug to pin 11 of the cjb plug. Cut the wire about 4-5 inches from each plug, solder and heat shrink wrap the splice. When you run the wire avoid any metal contact and zip tie in place once the connections are complete.
03NavigatorGuy
03NavigatorGuy
Memphis TN
I replaced the Neutral safety switch AKA: Transmission Range Sensor, and after doing so. The engine will not start in either park and/or neutral. Is there another sensor that is now blocking this from happening?
NOTE: With the "new" temp wire, the transmission selector indicator illuminates, the brake release for the transmission now works again, and so do the turn signals.
stamp11127
Temple, Georgia
There is a procedure to follow in lining up the range selector to the neutral position. Did you follow it?
Ahhh... the importance of only working on one issue at a time...
stamp11127
Temple, Georgia
If you replaced it with a Ford part the service manual says to use a special tool. You may be able to adjust it by checking continuity with the plug disconnected between pins 10 & 12 in both park and neutral.
03NavigatorGuy
03NavigatorGuy
Memphis TN
Sometimes I get OBDII to connect to my scanner, and sometimes it doesn't. For example yesterday I got my scanner to read the codes, and today I went to clear them and it wouldn't connect.
stamp11127
Temple, Georgia
You'll need the diagrams that show the DLC on them, usually the power distribution diagrams have it. Check the engine controls diagrams, sometimes it is on them also.
03NavigatorGuy
03NavigatorGuy
Memphis TN
Okay, here is what I have, I hope they are "somewhat" legible!
  • DataLinkConnectorOverview1.pdf
  • ISOBusOverview1.pdf
  • SCPBusOverview1.pdf
  • ACPBusOverview1.pdf
  • USBBusOverview1.pdf
Hamfisted
Ft Lauderdale
Here's a DLC pin out diagram. Does your DTC scan tool light up when you plug it into the Expy's OBDII port ? It should, even without the ignition key on. It won't read any codes unless the key is on, but it should at least light up and come to life. I think it's fuse 41 if you're not getting any power at the OBD port. What brand is your reader ? Is it hardwired? or one of those Bluetooth type ?
With your volt meter measure pin 16, should be 12v or battery voltage. Check that pin 4 and pin 5 have less than 5 ohm resistance to ground.
03NavigatorGuy
03NavigatorGuy
Memphis TN
Yes, I have always gotten power from 16, even when other things were getting power. The problem is the it won't communicate with the scanner, and sometimes it will, but usually it won't!
