Buying a used ford expedition and most do not have HD tow package can one be installed aftermarket?
pete47
Chicago
question in title, would love an answer to this as i cannot find a definitive answer anywhere else online
Deadman
Of course you can, but it will cost probably $7-10K to do it right. Its FAR more complicated than it appears.... Especially if you have a 4x4.
It entails a new radiator, trans-water cooler, and adding a 7 pin and brake controller. All this is to up the cooling capacity for the associated loads. Keep in mind your Ford capacity is technically unchanged for warranty purposes whether you do these upgrades or not. Ultimately it will go by your GVWR at that point when you tow. If you do the upgrades pay attention to your payload and gross vehicle weight ratings to fly legal and you should be OK. It’s a lot more work than meets the eye. It’s a lot easier to get the right package. On the 3rd gens HD tow and 3.73s are included on all Limited and above EL models standard. Most were ordered with it unless they were a base XLT. Not sure if the 4th gen does the same, maybe expand the search to Limiteds over XLTs.
Dice Roll
Craps Table
Plenty of tow pack trucks out there. Hold out. Really should be standard equipment on anything other than the teaser priced most basic one.
shane_th_ee
Seattle
No. there are a lot of hardware and software changes between the two, including wiring for the 3.73 rear axle.
LovinPSDs
Houston
Deadman - Can you elaborate? I know in a 15-17 it's pretty damn easy... I'm also considering an 18+ and I guess I'm not sure what I'm missing.
NyackRob79
Nyack, NY
Don't forget the upgrade to a heavy-duty rear axle. Can't imagine that being a cheap job.
shane_th_ee
Seattle
Gordon - Is it a different axle or just 3.73 gears in the same axle?
The 3.15 and 3.23 are both non-limited slip. The 3.73 is an electronically controlled, hydraulically actuated limited slip differential with locking mode. So there’s a different housing, a wire harness, a hydraulic pump, software, etc, etc. Oh, and the HD tow package also gets you different springs.
Deadman
Read thru the links someone posted in here, theres a LOT involved. Software and all the electronic locker stuff, the 2 speed transfer case, etc. Abs reluctors, gear swap, and all the unthought of did bits that the computer flips out over!
Kmdcolo
Does the 3.73 hold you back better when engine braking? I came down Teton pass this past Saturday with my non HD tow max. I was in 1st gear with engine screaming trying to keep it below 40 mph. My trans temp was 238.
This was pulling ~2,500 lbs (trailer + 1/2 cow) with 8 people in my expedition (6kids).
for reference, Teton pass is 10% grade with lots of hairpin turns.
Wangle
Des Moines, IA
There is an easy way to convert a 4th Gen if you don’t have the tow package. Simply trade it in for one that has it. WAY cheaper!! We were very surprised when we started looking for a replacement for our 2003 in early 2019. We wanted a 2014-16, but we made the mistake of test driving a 2018, which sealed our fate. The surprise came at the lack of a standard low range on the 4x4. We had to drive over 500 miles to get one with the tow package at the price we wanted. Don’t compromise on one without the tow package!!!
sanman28
SW MO
Had to have built with all the stuff i wanted....including tow.
shane_th_ee
Seattle
I also had to order mine. Early on Ford had trouble with the production rates of the 3.73 rear axle. My impression is that for much of the 2018 model run 3.73 rear axles went to Navigators and customer orders. So I’m not surprised that used Expeditions with the HD tow package are hard to find. They were really hard to get new. How hard were they to get? Most of us who did order were given estimates of ~ 8 weeks but didn’t actually get ours until 14-18 weeks after the order was placed.
duneslider
Utah
That's interesting, I couldn't find a single used 2018 with tow package when I was looking. Ended up buying a new 2019 for that reason and even then it was hard to find an xlt with the HD tow.
Deadman
My dealer told me as well that VERY few 18's came with Tow pack unless ordered. I luckily found a hold over brand new 18 with it on....
