Thoughts after first tow, and how fast do you tow?
gtncpa
NJ
I pull an 18 foot 6500-pound (loaded) double axle car trailer when I take my car to the race track. The Ecoboost pulls much better than my 2014
azmoondawg
Tucson
I pull a 3 axle boat trailer a little heavier than yours. I have about 650 lbs on the tongue. I've been pulling for a year and a half now, almost all towing at highway speeds. Here's what I learned. Take off the stability control. When I hit 70 for no apparent reason the stability control system kicks in. It brakes various wheels as it sees fit. First time it happened to me it was scary, thought I had a catastrophic tire failure on the trailer. The vehicle started moving all over the place. Happened a few more times till I studied up and realized I was safer towing with the stability control off. Second thing that I learned: air up the rear tires their max. In my case that is 44psi. The door sticker has them at 35 psi. This change had a huge effect. With 44psi in the rears the vehicle was no longer a little "twitchy" at speed.
That said, I try to keep it under 70 mph. I towed the same boat/trailer previously for 14 yrs with an 2005 3/4ton 4wd, 8.1 suburban. The 2019 Expedition has 6 inches shorter wb, is a little lighter and the suspension is softer. But it does the job. Gas mileage with the boat behind not much different. Burban got 6mpg, new Expy gets 7. But without the boat behind the Expy gets 16 city, 19 hwy where the burban got 10 - period.
FYI - I pulled the same boat/trailer the first two years I owned it with a 99 Expedition. I had Firestone airbags in the rear coils, and they blew a couple times, but it did okay.
Good Luck
Lou Hamilton
I tow my 25' Airstream - rated for 7,300lbs, but weighs 6,600lbs, loaded and ready to go.
As others said, proper set up in important for any trailer/TV combination. Weight distribution does not mean it has sway control. You need both. Yes, Reese dual cam is a good option- it's what I use.
Set up is not all that hard, sometimes it takes a little time to do all the tweaking. Then go to the scales and confirm.
I'll do 65 on the highway.
Would love to see a pick of your setup.
After talking to my wife and seeing the tank sizes, the 23’ is not an option any longer. A 25’ is in our future. Maybe within 2 years. :)
Wayne Decker
New York State
I can't really believe I don't have a photo. A haven't even taken it out of the barn yet due to the lock down. We had a 20' and then got 25' rear bedroom twin. It's the best.
If you want to discuss it, let me know.
Greg Parker
Arizona
New member here...
Brand new (holdover) 2019 Expedition Limited 4WD owner. I tried ...and tried ...and tried to convince my wife that she could handle a Ford Expedition (she drives a '16 Honda Pilot now). But the additional size/bulk of it was beyond her limit. (Her preferred vehicle size is like Honda CRV / Suburu Outback size). Sooooo, after a LOT of hand-wringing, I sold my old Chevy Duramax 2500HD and as such, the Expy is now our new tow vehicle for our '19 Jayco 26' camper. It has a GVWR of 6100#.
My Limited has the heavy-tow package and before I even knew it was required, I purchased a Husky Center-Line TS WDH (apparently handles sway control as well). I've researched it a ton and this was the most recommended WDH from most of the RV'ing community and dealer network. (I bought the 800-1200# version, model #32218). Well, maiden voyage with that will be this coming weekend, when we go camping to around 7200' elevation. I will report back on my experiences.
View media item 7185View media item 7184View media item 7186
LG_123
Toronto
I tow a 34' airstream, about 9000 lbs and don't like to go much above 65 even with a perfectly set up hitch system. The sway can start to become more than what I'm comfortable feeling at faster speeds.
D
Dice Roll
Craps Table
New member here...
that will be interesting for sure
Greg Parker
Arizona
You are a braver man than I for sure. I'm a 60-75% towing capacity kinda guy, but I still love that you're pushing max towing capacity.
ETC13
TN
I would have to think with this weight trailer that you are over the payload capacity of the Expedition.
Sent from my moto g(7) using Tapatalk
gtncpa
NJ
New member here...
Welcome aboard!!! Great pics of the Expi and camper. We are thinking of getting a camper. We have been watching a show where they give a buyer three options and they buy one. My wife wants a class A diesel pusher .... I want a travel trailer. (I hope I win)
JasonH
Houston, TX
I use the same hitch. My trailer is 33 feet. It works well when properly configured. You may have to play around with the settings a bit. We kept adding things to the trailer, so I had to make adjustments over time. Congrats and safe travels.
D
Dice Roll
Craps Table
what show is that? Sounds cool. We are in beginning stages of a purchase decision.
gtncpa
NJ
Great American Country is the channel. Going RV is the show. They have a few shows I watch. Another one is Lake Front Bargain hunt.
Fasttimes
Miami
I've been very happy with my Equalizer 10k hitch. Very easy to use. Took a while to get it dialed in though. First year of trips were white knuckle while I played around with it. Ultimately more weight transference to the truck's front axle got it right. Now she tows much more stable and enjoyable.
I'm towing with my 2010 EB Expy with HD tow package. Equalizer WDH. Another improvement that I learned was for the first year I was only airing up the tires to the Ford specs on the car. This added to more sloppiness while towing. Now I load up the tires prior to the trip to the tires MFG max allowance. That really helped.
Trailer is 30' total length, 6360 dry weight, 7700 GVWR. Probably towing average around 7000, but I haven't been to a scale. Lately I've been paying more attention to my trucks payload capacity and removing unnecessary weight from the camper. Just because you got the room in the trailer doesn't mean you really need it. I've noticed a much easier ride now that I've trimmed the fat from the camper and avoid putting anything in the back of the Expy. Better to put stuff in the camper and over it's axles if possible.
I've found that 65mph is my sweet spot for stability and gas consumption. I just set the cruise control and stay in the right lane. I find it lowers my stress.
I am curious to see what the difference in feel/tow power is between my V8 and the turbo 6s they use now. I'm eyeing to upgrade to 4th gen perhaps next year.
gtncpa
NJ
I tow about 6,000+ pounds. I had my 2014 and now I have the Eco 2017. The Eco tows better. I notice it, especially on hills. The downside to going up hills easier is gas mileage is worse than the 2014. My 2017 gets better gas mileage than my 2014 almost always except for towing and if you put your foot into it often.
Fasttimes
Miami
Hope it's not worse than the 7-8 mpg I get now when towing?
Bury
I haven't read all the posts, but if you want to really really reduce your sway and feel comfortable towing, Google the ProPride WDH. It's expensive, but IMO well worth it. I pulled a 25' TT with a Reese with two friction sway controls, and traded out for the ProPride. What a difference.
