4th Gen Expy FORScan Modifications
Super Moderator
Super Moderator
Has anyone worked out all the differences for the 2020s yet? How visible is this to a dealership?
There is a 2020 Specific Thread...I suggest you post in that, at least I thought there was. Maybe all the discussion happened in the 2019 thread. Oh Well!
If you are using the newest Forscan all of the quick easy change stuff for the BCM will take care of most things.
The IPC is mostly the same, haven't compared it line for line to 2019 code. The BCM is COMPLETELY different. No coding from 18/19 should be used for the BCM. APIM has some small differences, but everything I have tried coding wise has worked. APIM has the easy coding/Drop down change option. I recommend using that.
All of it is visible to the dealer if they look. The APIM changes can be seen by Ford when Sync checks for updates. No dealer is going to care about the changes as long as you don't blame Ford for something not working when it was clearly you coding something wrong.
Also if they do module updates because of a bulletin or TSB from Ford, the changes could be wiped.
Julio Walker
SA, Texas
Anyone is San Antonio willing to help me out and remove the double honk? I only have a Mac.
Thanks!
Julio Walker
SA, Texas
Does anyone have a link to the 2020 changes? I didn’t see a 2020 thread in here....
I was able to install VMware and windows. I have a WiFi adapter, and a wired one that I used with my BMW, so hopefully one of those will work...
Super Moderator
Super Moderator
DO NOT use the spreadsheets. 95% of what you might want to change is in the easy config drop downs. Most are either BCM or APIM.
KSC 2019 XLT
DFW
Hi all, this forum has helped me out tremendously and after reading and going to different websites to learn, I have finally started using Forscan version "2.3.35 beta" installed on my laptop in early Oct 2020. I have a 2019 Expedition XLT 202A package 4WD and I did my first update today using the easy mode (the non "AS BUILT format" modules) so I don't have to deal with spreadsheets and codes. I was successful disabling the no key double honk and fog lights on in high beam. However, I "Enabled" engine temp and engine oil gauges but both did not work. Would anyone know why or have dealt with this? Do I need to use the "AS BUILT format" module and enter the codes (freaks me out so rather not if I don't have to)? Also, I'm trying to locate the turn signal blinkers module so I can change it from the 3 blink default to 5. Does anyone know where it is located? Thank you all for your help!
Slipstream
Utah
Hi, yes if I recall correctly I had the same issue, but it worked using the codes...dont freak out, just write down what you are changing.
hsquared360
