Is this something that can be altered using Forscan?
Ours is 2020 Limited Expedition, and not seeing the ambient light choices anywhere![]()
we are resetting the garage door today so will keep y’all posted if it works
That's kind of absurd, cost cutting my rear. Technically, the more of them you buy the cheaper they should get per unit. I mean you're talking maybe a few cents per diode to go from a static diode to one that can change wavelengths. Man that's frustrating, especially for new buyers.
I have a 2020 Platinum Max and haven’t found an option to change the color of the ambient lighting (admittedly I haven’t done a full scan of the owners manual yet). Are we sure it was retained on this trim level for MY20?
I had looked in the menus, but not too well thinking this option was eliminated for all trim levels in 2020. I’ll check again and report back.That was what I was told by Ford Customer Service. It is in the Sync 3 menus. Have you looked?
#2. You need the original garage opener remote. You have to press the learning code button on your opener, press the remote and the homelink button.
We reset the garage door and tried the book method, online method, YouTube, you name it we tried it again! Garage door will not program (and we reset the buttons just incase even though it’s a new car)
Going to get the dealer to try it, we also have condensation in both tail lights and we just bought this thing 1 month ago todayugh... frustrating
It’s 2012 Chamberlin w/ myQ. And yes we tried programming it with the remote in the car & the learn button, have tried it all. Followed directions in book, directions online, YouTube, you name it we tried it. Even had 2 neighbors try, nothing![]()
I don't know for sure, but if you just bought a 3rd party replacement then yes, that could be the issue. However if you buy a Chamberlain remote and that IS the problem that's how you solve it. That could certainly be a security feature.No it doesn’t
I will say that we did not have the original remotes, we had to buy replacement remotes and then programmed them to the garage door. So the remote we are using is not original chamberlain remote. Does that matter?
