Fordgirl01
I will be sure to keep you posted!
Remember to use some assembly lube on the cam bearing surfaces and lobes to prevent a dry start up. It's good to take an oil squirt can and squirt motor oil on any moving parts too. Like the timing chains and guides, cylinder walls, rocker arms, etc.... I would leave the crankshaft position sensor unplugged and just crank the motor for a minute to get the oil pressure up and oil cavities full, before actually starting the motor. Leave the sparkplugs out until you get the heads and timing gear back together to make it easier to rotate the crankshaft by hand to make sure timing is correct and there's no piston on valve interference issue. Then install and properly torque the sparkplugs. If you did not pull the drain plugs out of the sides of the block before removing the heads, you may very well have coolant in your oil pan, and this requires an oil change before ever cranking the motor. You don't want to introduce coolant into the oil passages. Drain the oil, and if you do in fact see water (it'll come out first before the oil...) spray some brake cleaner into the oil pan after you think all the oil is out, just to help flush any more water out. The brake cleaner will quickly evaporate and won't affect your new oil.
Remember to use some assembly lube on the cam bearing surfaces and lobes to prevent a dry start up. It's good to take an oil squirt can and squirt motor oil on any moving parts too. Like the timing chains and guides, cylinder walls, rocker arms, etc.... I would leave the crankshaft position sensor unplugged and just crank the motor for a minute to get the oil pressure up and oil cavities full, before actually starting the motor. Leave the sparkplugs out until you get the heads and timing gear back together to make it easier to rotate the crankshaft by hand to make sure timing is correct and there's no piston on valve interference issue. Then install and properly torque the sparkplugs. If you did not pull the drain plugs out of the sides of the block before removing the heads, you may very well have coolant in your oil pan, and this requires an oil change before ever cranking the motor. You don't want to introduce coolant into the oil passages. Drain the oil, and if you do in fact see water (it'll come out first before the oil...) spray some brake cleaner into the oil pan after you think all the oil is out, just to help flush any more water out. The brake cleaner will quickly evaporate and won't affect your new oil. I might've missed it in your previous posts, but I Melling High Volume oil pump upgrade is highly recommended too.
https://www.rockauto.com/en/catalog/lincoln,2001,navigator,5.4l+v8,1434768,engine,oil+pump,5564
Also you might replace the crankshaft position sensor there on the timing cover before you reinstall the cover ( Motorcraft DY922 ). It's a lot easier that way, rather than fighting with the AC compressor if it goes bad in the future. Make sure to clean out the harness plug with some contact cleaner or brake cleaner because the way they mount they collect grime over the years. Once it's cleaned out apply a little dielectric grease to it before you plug it back in. That'll help keep moisture out of it and prevent hard starting or no starting problems later on.
Do you have a set of Gearwrench Flexhead Ratchet wrenches already ? You'll need a 8mm Flexhead wrench to get the bolts in and out on that oil pump unless you drop the oil pan. It's a huge PITA anyway you look at it.
https://www.amazon.com/GearWrench-9...254744&sprefix=Gearwrench+8mm+,aps,196&sr=8-9
Just make sure its the 8mm with the head that swivels...
https://www.amazon.com/gp/product/B...812GO&linkId=643c3c57a0aad4c3add579d9abac5c4c
Here is a guy that does the 2v timing set, yours is different obviously for timing purposes but some for the oil pump:
Edit: And yes that's the correct high flow oil pump
