Rear Sway bar?
Alwaysthinkin
Army
Georgia
It's the inside diameter of the bushing, coming in contact with the bar itself. The trouble is, it's not sealed, so dirt/water will get in there, and wear the grease down. I use a very good mechanical grease that's waterproof from Mobil1 and it still goes bad ever few months. Zercs halp a lot by pushing the dirt back out.
No experience here, just research:
Silicone lubricant with PTFE (believe that is a teflon additive) was recommended. Suggestion was lubricant from the same manufacturer MIGHT be better for the polyurethane bushing. In the case of Energy that would be Energy Suspension Formula 5. I just picked up 8oz from the local Summit Racing store today. (First time in, pretty cool store.) Other product names listed that had been tested by various pressure sprays were Prothane and Super Pro.
Believe I will try the teflon tape, can't see a downside. If anyone else sees a downside please give a holler.
Alwaysthinkin
Army
Georgia
Double post
5280tunage
colorado
But I believe you're talking about the end links. The bar mount bushings are from Stillen and I used the lubricant they shipped with, but it wore off pretty fast. I did try some silicon lubricant as well, no better.
Alwaysthinkin
Army
Georgia
Yes, end links are the discussion. I'll play around a little when I install but agree the teflon tape doesn't lend itself as well to the end links as it did with the control arms in the video. Sorry to hear the silicon didn't work any better, was hoping it would.
techdude99
US
I had good luck with Prothane grease years ago and I remember a Mobile 1 bearing grease that was really good.
5280tunage
colorado
That's the one. I've used this grease on everything from engine mounts to jack hammer pistons. Stuff is great. Water doesn't bug it but dirt is it's worst enemy.
Chio4
STL
FYI Front bars..
I have been chasing A noise and feeling that would occur at snow speeds over little bumps or manhole covers. I could feel it right at my feet when driving. well I looked at my bushings on the front bar and saw what was or could be movement on the bar. I decided to replace them and well SH*T that totally solved it. The Expedition feel like it did when I installed it 5k ago.
just thought I would pass this along. also I installed the hellwig ones that were sent to me when I replaced the rears for excessive noise.
5280tunage
colorado
FYI Front bars..
Not sure I understand. You replaced the hellwig bushings? With what. More hellwig?
Chio4
STL
yes I had an extra set of Hellwig bushings sent to me months ago. I wish I knew if someone had A better aftermarket bushing
ROBERT BONNER
Denver, NC
A little Ford history lesson from someone who was there...The Gen 2 rear suspension was amazing. Full aluminum double wishbone with toe links and anti-sway bar, allowed an adult size 3rd row with fold flat seats...and it handled much better than it's size would indicate. You could actually turn off the 4x4 and with a limited slip rear end you could do donuts in the parking lot without that special "about to tip over" feeling. The 4 wheel air ride only improved it.
But, the new Product Development VP at Ford, Phil Martens, was not a happy camper, he thought the IRS on both the Explorer and Expedition was a waste of money and wanted to undo it and go back to SRA on both of them. It was difficult to make him understand that in both cases it was all about superior interior package which was selling and hurting GM. In the end there was a compromise that pleased no one. The Gen 3 "multi-link" was hastily developed and launched. It was more expensive than the Aluminum Double wishbone with more unsprung weight, more variability, more attachments...and worst of all, it wallowed like a pig. But, it preserved the interior package; and, Phil was satiated because it was no longer a "race car like" Double wishbone. I was leasing a 2006 KR and a 2007 Limited at the same time for several months. My wife and I would do rock, paper, scissors to see who got to drive the 2006 every morning because we hated with the way the 2007 wallowed. The suspension is the same in the gen 4's as the gen 3's. I'm curious to hear from anyone on how the aftermarket anti-sway bars work. They look solid enough to restrict some of the link and bushing compliance which is the real problem, assuming that the bushings on the sway bar are sufficiently stiff. There are just too many links with too many bushings to keep the knuckles properly located. The stiffer gen 4 springs don't really help much because there is enough compliance in the bushings to sway the truck without compressing the springs.
hellohithere
My FSB is stuck on a FedEx truck until Monday. So much for the weekend install. Hopefully I'll be able to do the front like the rear, without ramps or a lift.
With the crappy roads around here I'm going to start researching smaller wheels so I can have more sidewall.
I'm confident both bars with new wheels and tires will be the right combination for my situation.
Did you end up installing the front sway bar? Would love to hear your thoughts.
5280tunage
colorado
I have both the front and rear, so incredibly worth it. Probably some of the best money I've spent on this thing so far.
D
Deadman
Wallow like a pig is extremly accurate with describing my 2018 brand new. My wife nearly puked riding in it.
Luckily the sway bars saved it. I honestly can't believe they sell them so horrible from the factory.
D
Deadman
techdude99
US
I decided to wait until completion of a long distance towing trip before installing the front. After 800 miles of driving on curvy & hilly roads, the current setup really demonstrated the improvement to the rear and the sloppiness (comparatively) of the front.
I'll be replacing the front this evening or next weekend. After my next trip I'll decide if it needs new shoes.
Knut
Been reading just about every single post in this link.
Is there any other manufacturer who makes replacement sway bar and are
just as good as these Hellwig bars appears to be????
D
Deadman
The front sway bar makes them handle sooooooooooo much better. All the corner lean is gone. It'll go thru a round about 15-20 mph faster now with ease.
techdude99
US
I'm not aware of any...
No members online now.
rockinghranch
