I was curious to see what I could find in the "as built" data set, so i cross checked my vin with two near identical ones on a dealer lot. I found some substantial gaps with a few common module codes. This is not perfect, and codes do change, but here's what I've found.
These modules exist for my build, but are missing programming code for large sections. at least giving me an idea of what "chips" are missing, as they don't have corresponding instruction codes.
The last one (721) has no data, but this system and code should exist.
No expert here, just doing some cross checking. so the actual "module" might not align with the first 3 digits of the code. but the code (first 3 digits) are what I have the gaps with. These match up with the 2021+ F150 alignment, so again, might not match the expy.
| ACM - Audio Front Control Module | 727 |
| IPMA - Image Processing Module A | 706 |
| RCM - Restraints Control Module | 737 |
| RTM - Radio Transceiver Module | 751 |
| VDM - Vehicle Dynamics Control Module | 721 |
