4th Gen Expy FORScan Modifications
Amamas2010
KSA
I wanna turn off auto daytime light when is the headlamp on auto I wanna work on the night . Can you help me about Code
apex96
i also have a 2018 expy, i have forscann and the license, and the elm327
the spreadsheet i had showed bambi mode as bcm 726-11-01,which is evedently wrong, getting in dash service request and error codes, ie. bumper sensors,lane assist,all sorts of stuff.
i cant find the original values .if any one would happen to have the original values for bcm 726-11-01
i would greatly appreciate it
thanks in advance
Input your vin into the website below and it will provide you with your factory as built data.
mdax21974
South Carolina
it is a limited , I ended up taking it to Ford. they said three modules were not communicating,and had to be replaced. they made a hotline call to ford corporate for the programming. still waiting
apex96
On the first page you should be prompted to enter VIN. On the second it should give you the option to download the as built file for the vehicle. Attached screen captures for guidance on how it should look.
AlterEgo
KSA
And that has been documented MANY times, many months ago.
I DO NOT recommend using the Super Duty sheet for making changes. Contact FORSCAN support and get the version of FORSCAN that works for the 2020/2021 Expedition and gives you the drop down options. None of these changes are worth screwing up your module programming over.
You are welcome to message the current owner of the sheet via the sheet and tell him, or start your own.
I personally believe the sheets get people in trouble, who have very little clue what they are doing. Use the drop down. If you chose not to, you better be backing up the modules.
@LokiWolf - For your response please.
Hello,
Trying to know what modificaitons can be done to my XLT 2020 202a (i assume it is 4th Gen) . I am new to ForScan. Got it installed with the evaluation license and synced up with VLinker MC+ (Bluetooth) . I only have had a look around without changing any settings.
Reading multiple posts by @Lokiwofl, I understand that any/all excel/google sheets containing modification codes are obsolete and should not followed anymore to avoid risk of damage and messed up configuration.
Any recommendation about the precaution while using the ForScan and what all tweaks are there that can be done for my model.
1. For example how/which options to ensure i have original backup of all modules before making any changes. Do i have to choose one by one backup of As-Built config of each module or there is any option which takes a master backup of all the settings and backup of the car.
2. I was unable to see any modifications list pre-built in ForScan menu. Can you post a screenshot to give a clue about the same.
3. Any other recommmendation for beginners.
Thanks for your response.
techdude99
US
I'm trying to disable the B&O DSP in my '19 Platinum Max. Would someone who's done it please confirm this setting in the picture?Screenshot_20230312_080418_DuckDuckGo.jpg
techdude99
US
Thanks Jake. Any side effects like a loud chime, etc... ?
seventieslord
I've got an 18, looking forward to seeing what I can do with Forscan. A few quick questions to start:
- one recommended adapter is $35, one is $150. What's the advantage to getting the more expensive one?
- I noticed in one of the first few posts (5.5 years ago), that the Forscan guys had not yet "hacked" the new generation so many features were not available. Has that been overcome by now?
- I've got the clicking mirror issue. TSB SSM47845. Can I use Forscan to reprogram the power mirror module to stop doing this?
