Auto Start Stop Damage turbo's?
Fastcar
Army
FL
Been bothering me for a bit. Does the constant stop and start shorten the life of the turbo. Always been the rule with a diesel to let it idle for a bit before you shut down, to help the turbo cool. Does this auto start/stop cause premature wear as the turbo is shut down immediately with no cool down?
Any thoughts?
Calidad
No but low quality oil and or going too long between oil changes definitely destroys these engines.
LazSlate
Arizona
You don't ask about your truck in a political forum, DO NOT talk politics in a truck forum.
Its the worst idea ever and causes so much premature wear to the vehicle. I would be venturing to guess on the wear of the turbos because turbos have bearings but they FLOAT on the oil which is pressurized. Look at any new turbo and the compressor wheel and turbine wheel wobbles by design and many think the turbo is bad, but when the oil pressure builds it floats on the oil which gives the bearing longer life and no longer wobbles. Similar to how crank bearings have no actual bearings, similar but not the same as turbo bearing design.
Also the CAM Phasers have to lock in to hold base timing then unlock with oil pressure then lock in again, back and forth.
We know that cam phasers had a bad design prior to 21-22 BUT maybe the auto start and stop also contributed to the premature failure.
MODERATOR EDIT: Political statement has been removed
dlcorbett
Air Force
tx
I jus instinctively hit the button now. I'm glad ford stleast let's us turn it off. My dads escalade won't let you turn it off...ur sol
Mr Big
Tampa Bay, Florida USA
You can default it to off, using FORScan or purchase an auto start stop module. However, I've read t it voids any warranty you may have. So, for now, I do the same.
dlcorbett
Air Force
tx
Yea I can't afford to void that warranty...then again my warranty hasn't covered anything thats gone wrong with my truck so far
SyndicateZ
Mass
lol go figure, right?
Pay big bucks for repair contract and the parts that decide to fail are always the one not covered or a part that is covered failed because another part that wasnt covered made the covered part fail thus making the warranty company (Ford Protect) not cover it and use that as the excuse to not pay anythings
Mr Big
I was thinking about getting a warranty after mine expires. but I keep hearing the same thing over and over.
With my recent service visit, the seatbelt circuit shorted out my seat massage control buttons on the side of the seat. My warranty covered the seatbelt, but I had to pay for the harness and button assembly. It even states that on my invoice.
rd618
new york
Who manages your warranty contract?
rd618
new york
I largely agree with this. The only 2 notes are that heat and pressure typically do the most damage to turbos. Bad oil too but that’s more rare for well maintained vehicles.
The start stop happens in the 500-800 rpm range typically far below most turbo high spool speeds.
The comment about diesel is actually for heat soak. The engines do heat up like crazy but newer blocks do a great job at dissipating heat. I’m also not familiar with any diesels that currently (modern) require you to keep them running. Almost all of that is now computer controlled with fans and dampers, and auto start stop is even more reliable and prevalent with diesels.
F
Fastcar
Army
FL
I think there are add ons that you can plug in behind the button to disable it.
Yeah but if ford see's it you'll be fighting a warranty claim as they will blame every failure on the modification or add on. Moss act doesn't matter to the bean counters.
SunnySunshine
SF Bay Area, CA
Take it off before you get it serviced. Other method would be tape the button down. The mods usually just short circuit the button anyways.
m3olsen
CNY
I know of at least two of the current marketed hard-wire solutions are not simply short-circuiting the button. They retain your last setting. So you can have ASS enabled, or disabled, at your choosing.
2018expyXLT4wd
I've had an Autostop Eliminator (www.autostopeliminator.com) installed on my 2018 Expy for 4 years - no issues, simple install. Mine is connected inline with the switch on the dash and retains the last setting (on or off). I turned my switch off 4 years ago and never touched it again. No more disabling the "feature" each time I started up.
F
Fastcar
Army
FL
As I understand it the ass won't work if the battery is low. There has to be something that tells it the battery is low. Got to find what sends the low voltage signal to it and if possible disable it.
Alwaysthinkin
Georgia
Ditto - except mines only been in there for two years. Just can't imagine everyone having to hit that button every time they start there Expy that doesn't go "what the heck" (or something like that!) at least once in awhile.
