TSB 23-2249 - 2018-2023 Expedition/Navigator + Explorer - Momentary Neutral-Out Condition In Drive
HazBeen
Great Lakes
*** Edited to remove parts lists due to Forum word-count limitations, see attached PDF file for full information ***​
TECHNICAL SERVICE BULLETIN 23-2249
Momentary Neutral-Out Condition In Drive - Excluding Police Interceptor Vehicles
November 06, 2023​
This bulletin supersedes 23-2120.
Model:
Ford
2018-2021 Expedition
10R80 - built on or before 29-Apr-2021
2020-2021 Explorer10R80 MHT - built on or before 14-Feb-2021
10R60 - built on or before 25-Jan-2021
Lincoln
2020-2021 Aviator
2018-2021 Navigator10R80 - built on or before 29-Apr-2021
Summary
This article supersedes TSB 23-2120 to exclude Police Interceptor vehicles with column shift.
Issue: Some 2018-2021 Expedition/Navigator and 2020-2021 Explorer/Aviator vehicles equipped with a 10R80/10R80 MHT or 10R60 (excluding Police Interceptor vehicles with column shift) may exhibit a momentary transmission neutral-out condition while in drive. Vehicle may also have diagnostic trouble code (DTC) P07E6 and/or P07E4 stored in the powertrain control module (PCM) or transmission control module (TCM) and/or a possible audible noise. This may be due to a leak in the park valve circuit. To correct the condition, follow the Service Procedure to inspect the park system hardware for wear or damage and replace the valve body separator plate with an improved valve body separator plate.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicles:
- 2018-2021 Expedition/Navigator - 10R80 - built on or before 29-Apr-2021
- 2020-2021 Explorer/Aviator - 10R80 MHT - built on or before 14-Feb-2021
- 2020-2021 Explorer/Aviator - 10R60 - built on or before 25-Jan-2021
• Non-column shift vehicles
• Momentary transmission neutral-out condition
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2018-2021 Expedition, Navigator 4X2/4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249A​
3.9 Hrs.​
2018-2021 Expedition 4X2: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249B​
10.1 Hrs.​
2018-2021 Expedition 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249C​
11.0 Hrs.​
2018-2021 Navigator 4X2: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249D​
10.4 Hrs.​
2018-2021 Navigator 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249E​
11.3 Hrs.​
2020-2021 Aviator 3.0L 10R80 MHT 4x4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249F​
3.3 Hrs.​
2020-2021 Aviator 3.0L 10R80 MHT 4x4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249G​
10.7 Hrs.​
2020-2021 Explorer 3.3L 10R80 MHT 4X2/4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249H​
3.3 Hrs.​
2020-2021 Explorer 3.3L 10R80 MHT 4X2: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249J​
10.8 Hrs.​
2020-2021 Explorer 3.3L 10R80 MHT 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249K​
11.3 Hrs.​
2020-2021 Aviator 3.0L 10R60 4x2/4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249L​
3.2 Hrs.​
2020-2021 Aviator 3.0L 10R60 4x2: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249M​
9.2 Hrs.​
2020-2021 Aviator 3.0L 10R60 4x4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249N​
9.7 Hrs.​
2020-2021 Explorer 2.3L 10R60 4X2/4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249P​
3.2 Hrs.​
2020-2021 Explorer 2.3L 10R60 4X2: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249Q​
10.4 Hrs.​
2020-2021 Explorer 2.3L 10R60 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249R​
10.8 Hrs.​
2020-2021 Explorer 3.0L 10R60 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249S​
3.2 Hrs.​
2020-2021 Explorer 3.0L 10R60 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249T​
9.7 Hrs.​
2020-2021 Explorer 3.3L 10R60 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Pass) Replace The Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249U​
3.2 Hrs.​
2020-2021 Explorer 3.3L 10R60 4X4: Retrieve DTCs, Remove The Main Control Valve Body And Auxiliary Pump Inspect (Fail) Replace The Output Shaft, Planetary Carrier, No. 4 Assembly. Park Pawl, Actuator Rod And Main Control Valve Body Separator Plate (Do Not Use With Any Other Labor Operations)
232249V​
11.4 Hrs.​
Repair/Claim Coding
Causal Part:7Z490
Condition Code:42
Service Procedure
1. Remove the main control valve body and transmission fluid auxiliary pump assemblies. Refer to Workshop Manual (WSM), Section 307-01.
2. Inspect the park pawl actuator rod/cam assembly for signs of wear or damage. Refer to WSM, Section 307-01.
3. Is there evidence of wear or damage on the park pawl actuator rod/cam assembly?
(1). Yes - proceed to Step 4.
(2). No - replace the main control valve body separator plate. Refer to WSM, Section 307-01. Repair is complete.
• It is only necessary to separate the upper valve body from the lower valve body to replace the valve body separator plate.
4. Reinstall the transmission fluid pan and bolts to prepare for transmission removal.
5. Remove the transmission. Refer to WSM, Section 307-01.
6. Disassemble the transmission to replace the output shaft and planetary carrier No.4 assembly, park pawl and park actuator rod. Refer to WSM, Section 307-01 > Overhaul.
(1). It is only necessary to remove the following parts to perform the repair:
• Torque converter or hybrid drive unit (HDU)
• Transmission fluid pan
• Park override lever
• Intermediate speed sensor A [ISSA], and output shaft speed [OSS] sensors. Clean all metallic debris from OSS sensor.
• Disconnect TR sensor
• Fluid pump
• Output shaft flange (if equipped) (RWD)
• Output shaft nut (if equipped)
• Using a punch, remove and discard the manual shaft-to-TR sensor roll pin
• Manual shaft, the TR sensor and the park pawl actuator rod. Discard the park actuator rod
• Front support
• Clutch and planetary assembly
• Output shaft and planetary carrier No. 4 assembly. Discard the output shaft and planetary carrier No. 4 assembly
• Output shaft seal
• Park pawl. Discard the park pawl.
7. To reassemble the transmission, reverse the disassembly procedure. Refer to WSM, Section 307-01 > Overhaul.
(1). Perform the T3 selective shim measurement to calculate the correct shim thickness needed.
8. Replace the main control valve body separator plate. Refer to WSM, Section 307-01.
(1). It is only necessary to separate the upper valve body from the lower valve body to replace the valve body separator plate.
9. Install the transmission. Refer to WSM, Section 307-01.
10. Perform an adaptive learning drive cycle. Refer to WSM, Section 307-01.
© 2023 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
  • TSB 23-2249 - Momentary Neutral-Out Condition In Drive - Excluding Police Interceptor Vehicles...pdf
Atlanta area
Just got back my 2020 Limited after 10 day to do this repair. My dealership was really good. I had a rental (no cost) for the time that I was out mine. Also I filed a complaint with the NHTSA because I believe there should be a recall for this. If you are trying to enter onto an Interstate and you lose power just as you are merging it could be disastrous..
mijoedoc
Tennessee
We were on I-75 north of Atlanta when we experienced the "Neutral Out" condition. Went to pass and the RPMs red-lined while speed decreased. The little wrench light came on the dashboard as well. Luckily we got to a rest area. When I restarted, the wrench light was off and the transmission seemed to reset. It was better, but I still had some rough shifts. Cruise control still worked the rest of the way home to Nashville. When I got it to the dealership for repair, it had 59,996 miles on it. Just under the 60,000 mile Powertrain warranty. I took a picture of the odometer so Ford could not somehow say I was out of warranty. It has been at the dealer for two weeks now. They told me again this morning they are still "tearing it down to determine the fix". They said they have been in touch with Ford regarding repair or replace the whole transmission. It's been a great truck for 3 1/2 years. Very disappointed with this experience. These transmissions are on millions of vehicles. How can this quality issue continue on some many vehicles. Although at least it happened to me before 60,000 miles.
bocabimmer
South Carolina
I had this happen to us while my wife was driving a few weeks ago. All I heard was what sounded like glass grinding in the transmission. Light went on momentarily and then went off. The truck has been completely fine since then. I went into Forscan and it had the neutral out code... unfortunately being my first time in Forscan, I inadvertently cleared all the codes instead of another specific one I wanted to clear. Resetting my shift tables also was of some help. It now does a much better job of handling the rough 4-5 shift by doing either 3-5 or 4-6.
I'm imagining it's going to happen again at some point, which is where my ESP will be handy.
GixxerJasen
DFW TX
And this is exactly why I went straight to my dealer and didn't even bother looking for any codes. I was too afraid to clear anything out. A full rebuild later and so far so good. Don't mess around, it can happen at a dangerous moment like it did for me.
inmanlanier
My son-in-law has a 2020 limited. Nice vehicle. We just did our annual 'catching' trip down out of the Louisiana marshes and drove from South Florida over and back Sunday/Wednesday. Without knowing of this TSB, he cautioned me when I first got behind the wheel of the symptoms of this issue with his car, which happened to him around 45 mph with significant throttle change - scared the pee out of him. Sure enough, one time driving over with me behind the wheel, I got the first wiff of it - fortunately with no risk where I was. The 2nd time however, was eastbound I-10 merging onto southbound I-75 - you have no advance visual of what's in the I-75 traffic southbound that you merge with. We rounded the moderately tight bend and there I am smack dab in parallel with a semi (cab to cab) and behind him is traffic. To me the only reasonable option is go forward and merge in front of the semi. I nail the throttle and the motor immediately shifts out of gear, engine revs going up with no motive power. I instinctively lift off the throttle and move it one more time - no response. Now I am running out of merge lane and now have to moderate brakes to try and merge in with traffic behind the semi. The first car is the usual sleezebag "I'm not letting you in, scumbag - this is a race I'm going to win!'. As I realize I can't get over I just decide to negotiate the road run-off (emergency lane) ahead of merge lane. The power resumed (I'm quite slow now), so I drove in the runoff until someone finally let me in. Quite the pucker factor moment. I'm amazed there has not been any lawsuits we've not heard of.
I'm on the Aviator forums (wife's car) and this one for my 2012 Expedition so I logged in last night and started searching. Found the older TSBs (same subject) and this one rather quickly.
THANK YOU ALL FOR POSTING YOUR EXPERIENCE. My son-in-law now has this and will schedule a repair.
QUESTION FOR ALL - has the TSB removed your symptoms and solved the problem? Thanks in advance.
inmanlanier
GixxerJasen
DFW TX
Eh, sort of. Still kinda clunky sometimes. I haven't had the failure yet in the little over a year since I had it done. I've also been a little gunshy about punching it like that again though, so hard to tell. I haven't had it back to the dealership to check for the bazillion errors it was apparently throwing prior to having the work done.
