What the heck happened to my rotor? And which kit should I get, Detroit Axle or Powerstop?
Adieu
SoCal
So, grinding noise from the back, then I see... THIS.
What/huh/what, how does that even happen?
Which kit should I get to replace it, Detroit Axle or Powerstop? Or is a 3rd reasonably priced alternative preferred? Thx.
Ryan L
Houston
How does the rotor on the other side look? If it is not wearing evenly, maybe check the calipers, pins, and brake hoses.
A
Adieu
SoCal
It looks intact.
Couple scratches and some rust, but it's ROUND and it's, like, ALL THERE.
Big_O
Atlanta
I changed all 4 rotors and pads to Powerstop Z36 and worked great. We tow a 3800 lbs camper and boat with good results. About 30k miles still going strong.
twodollars
On topic of detroit axle - purchased a set of their strut assemblies, had shipped to house. They sent me parts for a different application than I purchased. Got that straightened out, but a year later one of the springs cracked, so I had to replace again. One person's experience, but that was a crappy experience to be able to install junk parts. I'll not buy from them again.
Logan97
AZ
I've used detroit axle parts before on my in laws old tahoe, not worth it, they last about a year before needing replacement. I just use duralast rotors and duralast gold brake pads, usually last 4 to 5 years even with my hard driving.
Trailerhitch62
Raymore, MO
I had Powerstop pads and rotors on another vehicle and highly recommend them. Follow directions on breaking in the new rotors and pads, they’re excellent especially if you’re towing a boat or rv.
MidnightBruce
My 2016 EL I installed power stop and they have been wonderful. I have confidence when I need to hard brake. I needed to replace my factory calipers due to a blown boot on one of the pistons. So I replaced both at the same time and they now grab nicely.
Looks like your caliper got stuck or the pads disintegrated and it ate through the whole front rotor surface into the cooling veins. You should probably replace both calipers when doing the rotors and pads. One of those good preventative maintenance things. Don't cheap on brakes, it's the one thing keeping you safe when it matters most. For me it's my wife and 4 kids, and I need to know when I'm not there, that she can stop the beast on a dime. Hope everything works out!
Broncoholic
Space Coast, FL
I've been very happy with Duralast Gold rotors and Duralast Elite Ceramic pads on my '03 (installed Sept 2015!) and just did the wife's '16 last month. I've put over 50k miles on the '03 Duralast brakes.
