Help! Low beams won't work, high beams do.
Aggie97
Pearland, TX
I'm at a loss. Checked fuses and they are fine. Swapped out one bulb to see if it was the bulbs...no luck.
If not bulbs and not fuses, anyone have any other ideas what would cause the low beam headlights not to work?
Thank for any feedback.
Ferny
Same here
Im having the same problem and I can't find any threads elsewhere on this subject....fuses are good. I haven't replaced the bulbs but I can't believe BOTH would go out at the same time so it's got to be something else. Any info is appreciated...until then, it sits in the driveway =(
A
Aggie97
Pearland, TX
Mine is a 2007.
It's still umder my extended warranty so I'll end up taking it in but the timing sucks...I'm in the beginning days of a vacation trip so having to avoid night driving during the trip.
ELVATO
Orlando, FL
Hmm, I don't have a wiring diagram of those. Granted, it's a bulb; it's only two wires, + or - :p. It's a 9008, yes?
Is there a difference between high beams, and when you pull back on the lever (flash to pass). If I remember correctly, when you FTP, both the high and low beam filaments illuminate, where as in high beam mode, only the high beam filament illuminates.
ELVATO
Orlando, FL
EDIT:
Do you happen to have a multimeter or test light? If not, head over to walmart, they're pretty cheap there.
ELVATO
Orlando, FL
Don't think he ever responded. See post 5 and do the procedure.
EdandtheBullDog
Tennessee
Resolved
Thank you Elvato. Sure enough BOTH bulbs had died within hours of each other. The were PIAAs BTW. I replaced them with Sylvania XtraVisions that I got on sale. They seem to be as bright, but a bit more yellow. Hopefully they'll last longer.
ELVATO
Orlando, FL
Yea, I've heard PIAAs don't last nearly as long as some other aftermarket bulbs.
