1095C code abs and trac control lights on.
Limited Expy
Reno NV
I have a 2007 Limited. The ABS and trac control lights are on get 1095c code ABS pump. A mechanic tested the pump and passed then failed then passed. Any ideas on whether it is the pump and/or module? Or can it be something else.
Thanks
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Could be either or both, and since the pump passes then fails then passes, that would make me change it first, then the module...OR it could be a bad wheel hub, bearings, brake pads, or a leaking brake fluid line too, since they tend to cause error codes if/when they are going bad :)
