2004 Expedition doors banging
EEM2
Ohio
Have new struts on when hit a bump, sounds like doors are Rattling. Anyone have any fix for this?
Sounds like struts weren't installed right. Recheck your work, happened to me at dealership when I didn't tighten VW Jetta front strut proper, easy to mess up, easy to fix.
Habbibie
Is it Christmas yet?
Chicago
The whole question is one sentence long yet you still managed for fail miserably at grammer..... one sentence long!
He did use commas, ? Marks, and periods. Me I was absent the day of the sex ed class, I was home playing with my girlfriend!
E
EEM2
Ohio
Go work on your Expedition, and stop worrying about grammar. Go to a Oprah site. You F$ckhead
Habbibie
Chicago
You're an embarrassment to nature, first you can't for the life of you type one sentence as good as a 6 year old can let alone know how spell ********....
Being 46 it's not to late for you to go get your GED, you REALLY NEED IT!
ed_navarrete
Bethpage, NY
You should have written “...managed to fail...” not “managed for fail” and the word is “grammar” not “grammer” it sucks to correct people and then fail; my apologies for doing it to you.
ed_navarrete
Bethpage, NY
Please stop playing grammar/spelling police you’re failing big time
E
EEM2
Ohio
Basically your doors.
Don’t rattle.[emoji41]
johnboneske
Ohio
My Expedition does the same thing, when I hit a decent bump the back doors rattle, i have never found a fix for it I tried to thicken the weather stripping to no avail, tried to adjust the latches, which aren't adjustable, read somewhere that you have to replace the hinges/pins as they get worn out, so I left mine alone... Would like to know what others peoples fix is for the issue
Wegner44
Florida
My doors do the same thing. I have a theory that my 15 year old vehicle has weatherstripping around the door that has basically flattened and does not create the cushioned seal which originally kept the does from rattling. I am planning on replacing the door seals which should hopefully fix that issue.
Boddkr
Franklin
Hello,
My 2003 drivers door does the same thing. I found out it was the bottom strip on the outside of door. I replaced the body hooks on the inside of pieces. It fixed it.
johnboneske
Ohio
Hello,
Are you talking about that large rubber boot that's on the bottom of the doors themselves?
Boddkr
Franklin
The part on outside of door at the bottom. It snaps on with auto body clips
Sent from my SM-N950U using Tapatalk
Wegner44
Florida
Can anyone please take a picture of this on their vehicles? I'd really like to get my cabin noise level down, it has become pretty load....
Thanks!
johnboneske
Ohio
WOW! No kidding, by just replacing the "hooks" that hold those panels onto the doors it stopped the noise? Damn... Learn learn something everyday. So they tighten up the doors again? Cause I notice when sitting in my Expedition that when I pull/push the door handle quickly there is some easy movement on the doors, figured it had to do with latches or weather stripping
Boddkr
Franklin
I had to fix the inside window track to. We live in mountains and go down slot of dirt roads. So the bolt needs to be tighten.
