The whole question is one sentence long yet you still managed for fail miserably at grammer..... one sentence long!
You're an embarrassment to nature, first you can't for the life of you type one sentence as good as a 6 year old can let alone know how spell ********....
Being 46 it's not to late for you to go get your GED, you REALLY NEED IT!
Hello,
My 2003 drivers door does the same thing. I found out it was the bottom strip on the outside of door. I replaced the body hooks on the inside of pieces. It fixed it.
The part on outside of door at the bottom. It snaps on with auto body clipsAre you talking about that large rubber boot that's on the bottom of the doors themselves?
The part on outside of door at the bottom. It snaps on with auto body clips![]()
Sent from my SM-N950U using Tapatalk
I had to fix the inside window track to. We live in mountains and go down slot of dirt roads. So the bolt needs to be tighten.WOW! No kidding, by just replacing the "hooks" that hold those panels onto the doors it stopped the noise? Damn... Learn learn something everyday. So they tighten up the doors again? Cause I notice when sitting in my Expedition that when I pull/push the door handle quickly there is some easy movement on the doors, figured it had to do with latches or weather stripping
