5150 pops
Well I truly you hope see something significant from your sizeable investment
Remember that all that does does not recalibrate your transmission so I would be concerned about transmission durability
Really though you should get a tune designed to work with all of your upgrades that does indeed reprogram the trans to match the improved engine output
BTW
A stock pickup with 3:31 gears & 93 octane tune did
2. Dday0644 13.484 @ 100.12
-2017 SuperCrew 5.5' 4WD 3.31 10speed-
-MPT 93 Performance Tune-
3:73 gears in our EXPY would make for a lot quicker vehicle with the same calibration
Best of luck with all of your upgrades
I'm sure recalibrated shift points would in all likelihood be a lot more pleasant to drive, however that would have zero bearing on longevity (IMHO).
It's not like I intend to increase the output of the engine anymore than MAYBE 80Hp and 80/lb-ft at the absolute max. So having the HD Tow pkg and all the upgraded ancillaries to keep the components in check, I don't have a concern for the 98% of the time the vehicle is ferrying me to and from work, nor the 1.75% I tow 6500lbs, or even the .25% I would take it to the dragstrip over the next 5 years.
